Author: Subject: Removing something tigersealed in place
gaz_gaz
posted on 29/12/18 at 12:30 PM Reply With Quote
So I have a problem.
I tigersealed my rear carbon arch guards in place. Braced them in position and pissed off for a couple of days over Christmas.
1 of the guards has moved about 10mm while curing and now leaves a horrible cap where the guard curves to meet the body.
Does anyone know of a way to break down the PU Adhesive without wrecking the guard itself and ideally without ruining the rear arch and it's 3 stage pearl paint
jossey
posted on 29/12/18 at 01:04 PM Reply With Quote
I had to clean off a carbon cycle wing covered in tiger seal. Nail varnish and warming them worked but not perfect or quickly.
Good luck sorry I didn't find a easier solution
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
motorcycle_mayhem
posted on 29/12/18 at 01:09 PM Reply With Quote
I use this material (PU) a lot, from additional support for a battery, to bonding panels etc. Once it's cured, it's a struggle to release the substrates.
A Stanley blade can be slid between the substrates, or there's a knife thing in the kitchen (long, thin, but wide thing with beautifully rounded end) that the wife uses for something. Gentle tugging and a careful slide in.
Acetone will degrade and release the stuff, great for alloy panels or gelcoated GRP things, but not for painted wheelarches....
Methylene chloride (dichloromethane) will also do the same thing, and damage, but I suspect you won't have access to it.
Mash
posted on 29/12/18 at 02:10 PM Reply With Quote
Maybe some careful use of piano wire, very thin (or top E metal guitar string) ?
Still going to be s0d though
bigwill64
posted on 29/12/18 at 04:42 PM Reply With Quote
remove
you used to be able to buy kent bond softening spray for removing windscreen bond its american you could try ebay or kent/wurth website. or you try silicon eater from screwfix
posted on 29/12/18 at 06:35 PM Reply With Quote
Would a hot air paint stripper gun thingy be any use? Maybe warm it up a bit before scraping?
The older I get, the better I was...
Slater
posted on 29/12/18 at 08:01 PM Reply With Quote
Make a 2ft garote from some MIG wire and 2 wooden dowells. Use it like a flexible saw. It will take a while to do and you will break the wire many times, just make another one. I bonded front cycle wings with sikaflex. This was only way to remove them. stanley knife method was waste of time.
Myke 2463
posted on 30/12/18 at 09:07 AM Reply With Quote
Multi tool with 25mm serrated blade. easy.
Be Lucky Mike.
sdh2903
posted on 30/12/18 at 11:57 AM Reply With Quote
I was going to suggest this method but get some nylon fishing line instead of the mig wire to protect the paint.
posted on 30/12/18 at 03:32 PM Reply With Quote
Not had to un Tiger seal two parts before, but applying heat will almost certainly help. A proper heat gun will be too hot and harm the paint, but SWMBOs hair dryer can help (used my SWMBOs dryer many times to apply warmth). Once the parts are warmed then gently pull them apart. If you get the parts separated then you'll probably need to carry on warming the Tiger seal and gently rolling it of to clean the surfaces.
Best of luck.
