Author: Subject: 2000e Gearbox
Mike Bentley
posted on 3/1/19 at 06:07 PM Reply With Quote
2000e Gearbox
I have for sale a 2000e gearbox with 2.9-1 first gear ( one sold on e-bay for 540 before Xmas with gear lever and speedo drive)
mine looks good inside with no visible chipped gears or bulk rings, It turns smoothly and quietly in every gear.
It has no gear lever, clutch fork or speedo drive but comes with hydraulic bell housing and sandwich plate.
I bought from a reliable guy I have known for 35 years plus as part of an engine an gearbox package, I used the mint 1700 crossflow engine but not the box.
300 collected from Watford Herts before it goes on the dreaded Ebay.
Photos available on my Achive, you can contact me on
07811-350949 or michaelbentley42@gmail.com
Also Lynx manifold with 40 dcoe,
Another dcoe
race seats and frames
MK scuttle
2 x 325 lbs 2.25" X 7" springs
1300 cross flow and singe carb
32DFM 3 Carb and Manifold
Big Valve and ported chambered cross flow head
standard chambered cross flow head
alfas
posted on 4/1/19 at 11:38 AM Reply With Quote
can you verify the ratio other than you believe that the former owner told you the truth?
is there a pic of the box available?
Mike Bentley
posted on 4/1/19 at 05:28 PM Reply With Quote
2000e
I can confirm the ratios
I checked them buy jubilee clipping a piece of mig wire the tail shaft to act as a pointer and used mini mole grips
(Lightly gripped on the input shaft) and checked every ratio as follows
1st = 2.9:1 (almost 3 but did not go beyond 3 turns)
2nd = 2.0:1
3rd = 1.4:1
4th =1:1
All approx.
The official ratios are2.972, 2.010, 1.397 & 1
the other 1st gear ratios available are 2.5 (To high) and 3.5 (To low) and mine are know ay near these.
When I said a trusted person It was in relation to the condition
PM you email and ill email lots of photos
I,m having trouble loading them to my achive from my works computer for some reason
Mike Bentley
posted on 24/2/19 at 09:34 AM Reply With Quote
2000e box and other parts
Gearbox sold
I still have some of the other parts I listed
MK scuttle
