Author: Subject: mx5 ecu stuff
sprintB+
posted on 16/1/19 at 04:08 PM Reply With Quote
mx5 ecu stuff
Hi all, is it possible to run an mx5engine of a stock ecu. No dash, no lights, just the engine. Seems a huge number of wires in there doing nothing, can I just simply run it with just the engine running stuff.
miskit
posted on 16/1/19 at 05:16 PM Reply With Quote
Yes
Just remove this lot!
There is a main engine loom but you do need other bits.
On mine (1.8vvt) the speedo processes the speed signal from the gearbox that the ECU needs
[Edited on 16/1/19 by miskit]
ianhurley20
posted on 17/1/19 at 09:39 AM Reply With Quote
And on the Mk 2 engines the ecu controls the charge rate on the alternator - or you could change it for a standard alternator with a built in regulator. Also Mk 2's you will need the transponder key and PATs system retaining
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
Smoking Frog
posted on 17/1/19 at 10:04 AM Reply With Quote
The pinouts for the Mk1 1.6 ECU are simple to follow, allowing basic engine requirements. But with no information about the engine I would say Google "mx5 ecu pinout".
BaileyPerformance
posted on 17/1/19 at 10:47 AM Reply With Quote
Just for info, if it saves the hassle of stripping down MX5 looms / making them fit tidy and inevitable grief of pondering why it wont run right we offer FULL megasquirt installs for all kit cars, we are well known in the MX5 world for making them go faster!
We can offer to supply, fit and map MS2 to an MX5 engine in any kit car for 1100, this includes custom engine loom, you can even watch it been mapped.
This does away with the flow meter, and gives a noticeable performance gain over running the stock Mazda ECU. Customers also report an increase in MPG too!
Msg me for more info, Cheers, Dale.
www.facebook.com/baileyperformance
dale@baileyperformance.co.uk
