Author: Subject: Which fuel sender for aluminium fuel tank?
kevyo89
posted on 23/1/19 at 06:21 AM Reply With Quote
I'm after some advice on a half decent fuel sender for my aluminium fuel cell.
Anyone got any thoughts?
matt5964
posted on 23/1/19 at 07:52 AM Reply With Quote
I originally had a swing arm type but this proved to be in accurate and not great at below half tank due to the movement of fuel in corners.
I changed it to a tube version from the link below and everything is working well even on track
https://dmcomponents.co.uk/collections/fuel-senders/products/fuel-sender-for-square-or-rectangular-tanks
I use it with the stakk gauge like below, even though the Dash2 has the ability to display I use other functions and find the gauge easier to read cos I don’t want to be the one who red flags a session because of no fuel..lol
https://www.demon-tweeks.com/uk/stack-professional-fuel-level-gauge-249500/
This gauge is good as you can set the ohm it reads
It also displays the fuel level last read when switched off which is really useful
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
kevyo89
posted on 23/1/19 at 11:34 AM Reply With Quote
Thanks for this mate - really informative. I asked as I was sure the swinging arm type would be very inaccurate, especially around the track!
Maybe a daft question here but is the length of the fuel sender just determined by the depth of your fuel tank? I'm assuming it has to run from the very bottom to the top?
Mr Whippy
posted on 23/1/19 at 12:34 PM Reply With Quote
It doesn't "have" to be anything but if you leave a bit of a gap it will leave yourself a reserve that you won't try to use normally
matt5964
posted on 23/1/19 at 04:06 PM Reply With Quote
Exactly this
Mine is about 22mm from the bottom of the tank and I’ve got a swirl trap at the bottom so have quite a bit left when Hague reads empty
posted on 23/1/19 at 05:24 PM Reply With Quote
Did this myself so I had some fuel to spare and avoided running out of it.
peter030371
posted on 23/1/19 at 05:43 PM Reply With Quote
To what gauge?
Angel Acevedo
posted on 24/1/19 at 05:11 PM Reply With Quote
Interesting replies.
My point of view.
Gauge needs to be accurate enough at a sand still. If you are low enough to be worrid through the bends, you are already too low.
This doesn´t mean a wobbly needle is not an annoying thing.
Having your gauge read empty when there´s still fuel on the tang is like having your watch 10 minutes fast to avoid getting late to meetings...
I´d rather have my watch on time.
I bought my gauge/sender combo back when I had more "available car funds" therefore went for VDO. At that time I bought Water Temp, Oil Pressure and Volt Meter, Matching Gauges - and senders. All else will be displayed through an Acewell unit.
Hope this helps.
