Author: Subject: Radiator Choice????
sammini7
Contributor
Posts 23
Registered 14/8/17
Member Is Offline
Photo Archive Go!
Building: GTS Panther (Honda K20A + RX8 6 Speed G.Box)
posted on 10/2/19 at 10:28 PM Reply With Quote
Radiator Choice????
I have installed my K20A engine in my build and I am in the process of selecting a radiator, I am looking for a radiator good for up to 300bhp. Any ideas guys?
Regards
Sam
loggyboy
posted on 10/2/19 at 11:39 PM Reply With Quote
How much horsepower do radiators give?
Angel Acevedo
posted on 11/2/19 at 05:05 AM Reply With Quote
Witty answer,
But A large percentage of energy contained in fuel is dissipated as heat.
Therefore not bad phrasing for the question, I think...
I am still thinking on what to use on my 5.0.
Either an old style rad, or a new style/tech rad from a modern engine of the same HP rating.
big_wasa
posted on 11/2/19 at 08:41 AM Reply With Quote
I havnt run it yet but I've just bought a 55mm thick alloy rad from Coolex on a polo frame format. It's modified with the in and out at opposite sides to make it a single pass. Nothing bigger is gong in there. But they do a 70mm thick one.
I am hoping it will be upto the job.
Daf
posted on 11/2/19 at 08:55 AM Reply With Quote
I have a 55mm one from coolex exactly as descrived above. On the standard polo rad my fan was kicking in all the time, changing over to this though it never comes on anymore. Although I only have to dissipate ~180 horses worth of heat.
swanny
posted on 11/2/19 at 09:32 AM Reply With Quote
I have a dolomite sprint rad in my locost. engine is a 4litre rover v8. seems to have done a good job over 8000 miles, and several trips to le mans in the sunshine
40inches
posted on 11/2/19 at 09:37 AM Reply With Quote
I used one of these eBay Item Keeps the Jag engine at around 85 degrees, whatever the weather.
Done a couple of thousand miles, so far so good
ian locostzx9rc2
posted on 11/2/19 at 03:20 PM Reply With Quote
Big vote for coolex radiator
posted on 12/2/19 at 06:54 PM Reply With Quote
Depends on budget and space where it will fit, as well as inlet/outlet position and to lesser extent diameter.
First port of call is on a radiator manufacturer website to look at radiator dimensions fitted to cars with similar bhp.
Once you have chosen a few that fit, see price and take a look at eBay if an aluminium radiefor the car/model exists and in budget.
The last resort is custom, down side it is ££££ and secondly not being a standard part may take a while to get a replacement.
Visit China. Meet the child that made your trainers.
DavidW
posted on 13/2/19 at 07:40 AM Reply With Quote
I had a standard polo rad and it couldn't keep cool on a long hot track session. Swapped for the Coolex version which seems to have cooling capacity to spare.
