New Topic New Reply
Author: Subject: Compact rack and pinion for A7 Special
theprisioner
posted on 12/2/19 at 02:23 PM Reply With Quote
I am thinking of fitting a rack and pinion steering to my 1937 Austin seven Special.
It has a lot of non standard features so I am not destroying a potential concourse car.
Requirements
* Should ideally be designed for a car. There are lots of carting type racks around but not sure they are strong enough.
* The total width of the rack is paramout part of spec as there is little room for this mod.
* Ideally it should be a one sided rack as there is little room under engine and the rack needs to mount to one side.
Any Ideas welcome
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
watsonpj
posted on 12/2/19 at 02:36 PM Reply With Quote
SEICENTO is compact and one sided I think that's what they used in the Furore
Theshed
posted on 12/2/19 at 03:02 PM Reply With Quote
Its an fairly easy job to chop one to the right length....
jps
posted on 12/2/19 at 04:16 PM Reply With Quote
What width are you aiming for? BMC mini racks must be fairly narrow (and would maintain a marque link!)?
posted on 12/2/19 at 04:44 PM Reply With Quote
Might be a daft question, but by "one sided" do you mean the pinion should be offset to one side rather than in the centre?
theprisioner
posted on 12/2/19 at 06:10 PM Reply With Quote
Basically the steering has a link rod side to side retaining that may have some advantages. If I then link the rack into that with a ball joint it becomes a minimalist design. I don't have room for a double sided rack so compactness is desirable.
minitici
posted on 12/2/19 at 06:29 PM Reply With Quote
If it is just a worn out A7 steering box you have - why not go for a VW 1302 steering box like Paul Neil-MacLachlan fitted to his special?
(apart from the cost that is!)
If I ever get around to improving the Hamblin - that is what I will use.
posted on 12/2/19 at 11:31 PM Reply With Quote
If is still has the original beam front axle and you mount the rack on the chassis you are inviting a bump steer problem. Mounting the rack to the beam would fix that, but then you need a steering column that can accommodate the front axle movement.
theprisioner
posted on 12/2/19 at 11:35 PM Reply With Quote
It has the Bowden independent suspension
theprisioner
posted on 12/2/19 at 11:43 PM Reply With Quote
this is interesting if expensive
https://www.unisteer.com/1928-1940- street-rods/search-by-vehicle/ford/1928-1940-street-rods/cross-steers.html
posted on 13/2/19 at 02:46 PM Reply With Quote
Is that the system with the twin transverse leaf springs? If so you probably already some amount of bump steer, fitting a conventional rack could actually improve this if you get the geometry correct.
If there simply isn't room, then you could modify a standard rack to make it single ended, in much the same way people cut down Sierra racks for Locosts etc. The toothed parts of the rack is relatively short compared to the total length.
There are also racks that mount the track rods in the center of the rack rather than the ends, the Mk2 Astra and 7th Generation Honda Civic spring to mind.
theprisioner
posted on 13/2/19 at 04:28 PM Reply With Quote
Very good response I do not want to pay $500 for a US rack
New Topic New Reply
