Author: Subject: Fuel Pump
ttalps2000
posted on 15/2/19 at 08:18 PM Reply With Quote
Fuel Pump
What is the best HP electric fuel pump to go for at a reasonable cost? Will be running max 200hp non-turbo on a zetec on TB's.
Oddified
posted on 15/2/19 at 08:45 PM Reply With Quote
In tank or inline fitting?.
Ian
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Oddified 's Aim
ttalps2000
posted on 15/2/19 at 09:02 PM Reply With Quote
Inline
Myke 2463
posted on 16/2/19 at 05:18 PM Reply With Quote
From JJC RACE and Rally Universal External In-Line Fuel Injection Pump Bosch 0580464070 Replacement eBay item number:361025345369
Been using mine for 10 years with out any problem.
Be Lucky Mike.
ttalps2000
posted on 16/2/19 at 06:09 PM Reply With Quote
good to know that you have had no issues with yours. Always a bit put off by the cheap pumps due to the amount of trouble people seem to get with them.
BaileyPerformance
posted on 13/3/19 at 09:39 AM Reply With Quote
only buy genuine Bosch.
£90 Burton Power, in line.
Pump feed MUST be 12mm bore, gravity fed, no pre filter, filter after pump.
theduck
posted on 13/3/19 at 09:56 AM Reply With Quote
Wouldnt trust anything branded from JJC to be genuine
BaileyPerformance
posted on 13/3/19 at 10:04 AM Reply With Quote
Yep, Chinese shit
CTLeeds
posted on 13/3/19 at 12:08 PM Reply With Quote
I bought an APS branded 044 equivalent from JJC and it started to fail after about 6 months and it was horrifically noisy straight out of the box. I was having problems with fuel delivery over 5k rpm and the pump was the culprit. I couldn't recommend you to buy one. I have since bought a genuine 070 Bosch and it's a lot quieter and delivers what it says it should at all engine demands. The Bosch draws a lot less current as well which has helped my battery issues a lot.
Chris
ttalps2000
posted on 13/3/19 at 01:18 PM Reply With Quote
Genuine Bosch unit it is then!! Why no pre-filter? I have a swirl pot for it to run from my existing carb pump, not sure on the outlet size though
40inches
posted on 13/3/19 at 02:22 PM Reply With Quote
Chris
My understanding is that the 044 is a motor sport pump and is designed to be pressure fed by another pump,, or they are very noisy and prone to failure?
theduck
posted on 13/3/19 at 02:31 PM Reply With Quote
044 refers to a bosh part number, and the Bosch pump was an oe application pump. Like a lot of pumps though, they don’t like sucking on air.
40inches
posted on 13/3/19 at 02:34 PM Reply With Quote
Only commenting because when I was trying to find info, before I bought a pump for the Jag engine
I found an article on the Bosch web site, of course, now I can't find it
Can only find this Link
[Edited on 13-3-19 by 40inches]
CTLeeds
posted on 13/3/19 at 03:56 PM Reply With Quote
I read that thread on PH when I started having problems but it didn't really clear anything up for me. I do know that the JJC 044 pump was drawing over 25 amps which was causing me big problems? The 044 was also overkill though for my max 230bhp application. The genuine Bosch 070 is a smaller pump but much more suited to my application and is drawing around 7 amps. It was also a straight swap in terms of electrical and plumbing installation. It's solved a lot of issues for me.
Chris
Oddified
posted on 13/3/19 at 04:32 PM Reply With Quote
When i built my new project i fitted the 'equivalent' of a Bosch 044, labelled as a DA31. Nothing but issues and the noise, the video below doesn't really show how loud it was!
16mm pipe feed, pump directly under the tank, no pre filter so the feed side was spot on.
Bit the bullet and bought a genuine 044, night and day difference and quiet. I did a video on youtube showing the difference in noise, straight back to back just swapping the pumps;-
Ian
CTLeeds
posted on 15/3/19 at 10:11 AM Reply With Quote
Ian
Yep, great little vid. As you say, day and night.
Chris
