Author: Subject: Front Splitter - Show me yours!
chrisbmxr
posted on 18/2/19 at 02:48 PM Reply With Quote
Hi all,
I'm looking to make myself a front splitter for my MK Indy as I like the look of them, and wondered who had done something similar?
I'll probably mock it up with 5mm MDF, and then make the final item in carbon, fixed to bottom rails of the chassis with a couple of supports as well.
Thanks!
Mr Whippy
posted on 18/2/19 at 04:48 PM Reply With Quote
Hmm will a splitter on a 7 actually do anything useful?
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
chrisbmxr
posted on 18/2/19 at 05:08 PM Reply With Quote
Not particularly - apparently they can negate some of the lift caused by the nose cone. I like the look of them though.
loggyboy
posted on 18/2/19 at 05:23 PM Reply With Quote
Depends on how nuts you wanna go.
Doctor Derek Doctors
posted on 18/2/19 at 05:36 PM Reply With Quote
A splitter and full undertray made a hell-of-a-difference to the Life-Taker when I had it. I have since fitted a copy of this to a customers car and driver said the difference was instantly noticeable, especially in terms of drag reduction and stability.
Designer and Supplier of the T89 Designs - Single Seater Locost. Build you own Single Seater Racecar for ~5k.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
AdamR20
posted on 18/2/19 at 07:58 PM Reply With Quote
Agreed, makes a massive difference, especially on cars where the nose cone is sloping underneath.
Can't find pics of mine at the mo but will look tomorrow if I remember.
Edit: https://forum.wscc.co.uk/forum/uploads/monthly_2018_08/3sis.jpg.193e3ec13b41e6fb3b819fc099113252.jpg
[Edited on 19/2/19 by AdamR20]
peter030371
posted on 19/2/19 at 12:34 PM Reply With Quote
Although not as 'pretty' in some eyes (but is a '7' style car really ever pretty?) but a vertical, large number plate mounted as low as you can go also helps reduce the front end lift and is a cheap 'upgrade'
Bigger plate
Bigger plate
