<<  1    2    3    4  >>
Author: Subject: Time for another build - Avon
flak monkey
posted on 21/2/19 at 01:45 PM Reply With Quote
Well, it's been a while and I'm actually back with another build, finally. Egged on a bit by my partner who has always wanted a seven but didn't know where to start.
Nothing swanky about this one, a back to basics pinto engined Avon. Will probably stick megasquirt on it as a matter of course, but otherwise no supercharging or silliness. Have I grown up too much?
I might get off to a bit of a slow start as we are in the middle of trying to move house, but nonetheless everyone has to have a project, right?!
[Edited on 21/2/19 by flak monkey]
Sera
https://www.facebook.com/sera.jay666
https://www.facebook.com/SJEAmerican/
posted on 21/2/19 at 03:53 PM Reply With Quote
Good on you and yes everyone should have a project!
Nowt wrong with a Pinto engine IMHO either.
big_wasa
posted on 21/2/19 at 05:05 PM Reply With Quote
Unless you have one tucked away, have you seen the price a good pinto is fetching ? Same as the T9s
I know Tiger really are just around the corner but my money would be on an...
A) Mnr (mx5) B) Gbs Zero (mx5)
Lots of cheap donors and parts
flak monkey
posted on 21/2/19 at 07:06 PM Reply With Quote
I know a few people who can help with parts.
I was thinking about going duratec as they are getting cheaper, but once you add up all of the other parts and the emissions stuff for IVA it's still expensive.
Could still stick an mx5 engine and box in an Avon, no big deal. Already sorted for a Sierra rear end anyway.
Sera
melly-g
posted on 21/2/19 at 07:12 PM Reply With Quote
I think that's a great choice!
I am a bit biased though.
I changed the pinto for a zetec se last year.
It's good to see you back mate.
dmrider_10
posted on 22/2/19 at 07:21 AM Reply With Quote
Firm advoate for Mx5s (but then I have owned 9 of them....). All the parts are from a sports car, the engine is bullet proof and power is easily upped. They will pass MOT with no cat if using a megasquirt, super cheap, the original layout of parts is "correct" FRWD
theconrodkid
posted on 22/2/19 at 08:58 AM Reply With Quote
having seen the GBS zero, i would go for that, it is a lot more authentic looking...or be radical and go midi ?
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
Mr Whippy
posted on 22/2/19 at 12:10 PM Reply With Quote
have to admit an MX5 is the only way I'd go if doing one again and you can pick up a rusty one with good mechanical for utter peanuts
not sure just how many of the parts you can use and maybe get away with keeping the donor reg and avoiding an IVA?
With all my project cars gone and me now with a new tin top that needs nothing other than boring routine maintenance, a huge garage and all the tools, I have to admit I'm feeling the pull of building a 7 again myself...
Been out of the kit car stuff for so long now, not even sure if there is plans based on MX5 mechanics?
[Edited on 22/2/19 by Mr Whippy]
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
steve m
posted on 22/2/19 at 07:12 PM Reply With Quote
Good to see Sera back on here, and building, as her work on the bikes was amazing
I a little while ago had an urge to build again, but not a 7, as they are every were, infact not one day goes by when im out driving will see a 7, but I do live in the South east of England
I would, with enough garage space like to attempt a road legal Lemans 60's-70's car not for racing, with a big V8
But sadly, I don't have the garage space, nor the time, so I might make one 3rd scale, I could drive that
steve
Barksavon
posted on 23/2/19 at 07:38 AM Reply With Quote
I've got a 1.6 MX5 available as a donor. It's succumbed to the dreaded chassis rail corrosion, also corrosion in the sills.
I was intending to sort it but it's stood for couple of years now and just won't get time to do it.
flak monkey
posted on 23/2/19 at 10:41 AM Reply With Quote
I did think about going the MX5 route, but they really aren't that tuneable unless you stick a turbo on them, and that's not what I want to do.
Besides, I already have a Mk1 MX5 which is getting turboed anyway.
Set on the pinto route, its a nice simple and easy engine to work on and my partner wants to learn, so might as well start basic. Will probably stick throttle bodies and injection on it because I can.
Ultimately we are looking to build something simple and actually quite old school
I do have it in mind to build something a bit more extreme in the future too, but I am keeping that under wraps
Sera
James
posted on 27/2/19 at 12:15 AM Reply With Quote
Good to see you back mate! Only just come back myself!
Do you still have the yellow Camaro(?) you were rebuilding?
View User's Profile View All Posts By User U2U Member   James 's Aim
flak monkey
posted on 27/2/19 at 06:35 AM Reply With Quote
Hiya!
Sold the Camaro last year, ended up around 600hp LS swapped. Great fun, but my circumstances changed a lot and it had to go.
Sera
flak monkey
posted on 4/3/19 at 01:24 AM Reply With Quote
Well, I made a start....
Found a complete Sierra rear sub frame with 7" 3.92 diff etc so went and picked it up on Friday. Now I only have my little M140i I ended up having to dismantle it at the scrappies to get it in the car...
Needs a damn good clean and new boots on the drive shafts. Other than that, it should do!
Had a bit of fun with the grinder to remove the hub nuts, but all of 5 minutes and both were done. It's now completely stripped to it's component parts waiting to be cleaned up.
Also went and cleared out melly-g's garage of Pinto parts! Many thanks for that
4 heads in various states of repair as well as a short block when I get back to collect it.
Sera
flak monkey
posted on 12/3/19 at 09:28 AM Reply With Quote
Me and Sophie have been busy... This is Sophie's first time working on anything in this amount of detail - although she has a practical engineering background she has never rebuilt an engine. So I am quite enjoying having a student!
We are going to pick up our chassis and suspension etc this weekend! Need to clear my garage out as I only have a single one now
Picked up a couple of pinto short blocks, both in need of machining which isn't a problem. Have stripped down both and have identified enough parts to build a new short block from the parts without buying anything else too expensive. Although both are not 205 blocks, one of them had later rods in it anyway and one of them had been bored +0.5mm and the other was at standard. So we are going to get that one bored to +0.5mm and use the stronger rods and oversize pistons. One has a standard crank in useable condition too, so we have most of what we need.
I'm just waiting for a quote for the machining work (bore and deck skim)
I cleaned up the differential and drive shafts yesterday - ready for a lick of paint and new seals/boots.
Sera
posted on 12/3/19 at 07:05 PM Reply With Quote
Picked up a couple of pinto short blocks , both in need of machining which isn't a problem.
Ah, that explains it. I was wondering why the axis of Britain had tilted slightly towards Norfolk.
Hello BTW
Visit China. Meet the child that made your trainers.
flak monkey
posted on 13/3/19 at 09:28 AM Reply With Quote
It's true, the continental plates did shift slightly.
But they can't be that heavy as I managed to lift both of them in and out of the back of my car without much effort... and I'm only a weakling now
Sera
posted on 13/3/19 at 11:13 AM Reply With Quote
I use to do things like that. Until I gave myself a double hernia!
Nice to see you back .
Mr Whippy
posted on 13/3/19 at 12:54 PM Reply With Quote
I worked with a guy who when I went to collect it lifted a rover V8 out a SD1 with a rope round the engine and over his shoulders! mental sod
I did once carry my stripped down VW flat four up stairs into the garage loft but god it was heavy LOL
[Edited on 13/3/19 by Mr Whippy]
flak monkey
posted on 14/3/19 at 03:26 PM Reply With Quote
Shiny....
Sera
flak monkey
posted on 15/3/19 at 03:40 PM Reply With Quote
Going to collect my chassis and various other bits tomorrow morning - LWB van booked and an early morning I think!
Hopefully quickish progress will follow.
Popped into Tiger at lunchtime (since they are just up the road) and had a chat with Jim - seemed helpful enough, they are certainly busy, workshop is full. Gave me a copy of his book for my free so can't be too bad. Not that I am planning to need it much!
Sera
SJ
posted on 15/3/19 at 09:19 PM Reply With Quote
Looking forward to seeing the quality of your work! Makes mine look like a pig's ear.
Stu
Andybarbet
posted on 15/3/19 at 10:07 PM Reply With Quote
Looking good so far :-)
I will watch your progress as it appears.
What paint have you used on the diff ? It looks great.
SJ
posted on 15/3/19 at 10:10 PM Reply With Quote
To my point in my earlier post, mine came painted, circa 1990.
flak monkey
posted on 16/3/19 at 06:09 PM Reply With Quote
Its just wheel silver paint, nothing fancy. Gave it a clean and a coat of etch primer first of course...
Had a 350 mile round trip today to collect the chassis and various other bits. Hopefully have it rolling by the end of tomorrow. Need to sort out the fuel line and brake clips, but most of it's OK.
Think it's a Polo/Lupo steering column, need to find some bolts for it.
Sera
<<  1    2    3    4  >>
