<<  3    4    5    6    7    8    9  >>
Author: Subject: Jag V6 dyno results (at last)
big_wasa
posted on 18/6/19 at 05:14 PM Reply With Quote
I want to hear these bad boys sing, shiny shiny. Just a shame there no good for a 7
[Edited on 18/6/19 by big_wasa]
Partofthechaos
posted on 20/6/19 at 04:42 PM Reply With Quote
Originally posted by sdh2903
St200 inlet. Throttle inlet is just over 65mm. Smaller port is 30mm and bigger 31.5.
Jagin1
Jagin1
Jagin2
Jagin2
Jagin3
Jagin3
Thank you, definitely different then. I wonder if I can do anything with this one or if I've wasted £40.
big_wasa
posted on 20/6/19 at 05:06 PM Reply With Quote
If nothing else it will get you up and running until you find one.
Partofthechaos
posted on 20/6/19 at 05:18 PM Reply With Quote
Yes, it will allow me to wait till there is one at a good price. It still may be a good idea to reduce the power, stop me stuffing it into the first tree I try to go round. Or maybe not.
dazq
posted on 20/6/19 at 07:17 PM Reply With Quote
Originally posted by 40inches
I would be very interested in a copy of your msq file please, your rolling road results are really encouraging.
You have a U2U
Hi , have u2u my email Addy. Thanks
Badger_McLetcher
posted on 22/6/19 at 05:21 PM Reply With Quote
Right, I got me an ST24 inlet manifold to be getting on with, an ST220 throttle body and some 15mm aluminium plate to make some spacers out of. I offered up the Jag fuel rail but it's too tall - I'd need to make the spacer about 20mm. What fuel rails are you guys using? The ST220 and ST200 ones both look a bit lower profile.
Ben
If disfunction is a function, then I must be some kind of genius.
CosKev3
posted on 22/6/19 at 05:30 PM Reply With Quote
Standard AJ30 fuel rail on mine,with all the standard crap cut off the ends and AN6 fittings welded on.
ST220 injectors are at a different angle to AJ30,hence why a ST220 lower inlet wont fit.
What makes you say AJ30 rail wont fit?
[Edited on 22/6/19 by CosKev3]
sdh2903
posted on 22/6/19 at 06:49 PM Reply With Quote
There must be different versions of the aj30 fuel rail as mine is plastic?
Badger_McLetcher
posted on 22/6/19 at 08:43 PM Reply With Quote
Aye, mine is also plastic! Although that would now explain why it doesn't fit
Looks like a new fuel rail is on the cards!
sdh2903
posted on 22/6/19 at 09:19 PM Reply With Quote
Oh nutsack my freshly arrived 15mm ally will be useless then
Badger_McLetcher
posted on 22/6/19 at 09:32 PM Reply With Quote
Aye, looks like. Or you could swap to a different fuel rail, which is what I'm planning on doing as cutting out even 15mm thickness is a PITA!
CosKev3
posted on 22/6/19 at 10:45 PM Reply With Quote
What year engines did the plastic ones come off?
Both engines I've got had metal ones,strange
CosKev3
posted on 22/6/19 at 10:53 PM Reply With Quote
Oh yeah just looked on ebay,the plastic fuel rail lower inlet is quite different to the one with a metal fuel rail.
I think you will need to get one with a metal rail to work with the ST200 upper.
On the top of the metal rail I've cut the pipe inlet off flat with the rail,then welded AN fittings on the ends.
On the rear of the rail under the TB I've had to extend the rail with some steel pipe and angle it down so the rail exits under the TB.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F201946977532
40inches
posted on 22/6/19 at 11:15 PM Reply With Quote
Mine is the plastic lower, but I used the 2litre fuel rail because it's dead ended.
CosKev3
posted on 23/6/19 at 07:51 AM Reply With Quote
Mines got plastic lower manifold,but not plastic fuel rail
Also the gasket set up/seals are different looking at pics,mine with the steel fuel rail uses oval O rings to seal to head and also the upper,the plastic fuel rail set up uses gaskets by the looks of it.
sdh2903
posted on 23/6/19 at 08:57 AM Reply With Quote
This is what I have.
Jagplain
Jagplain
Seems to be the early engines had this set up then 01 onwards have the steel rail. This uses gaskets rather than the oval o rings.
Dave was yours the same as this? And you used the 2.0 v6 one? A straight swap I take it with injector fitment/angles etc?
sdh2903
posted on 23/6/19 at 09:17 AM Reply With Quote
In fact looking on the bigger screen on the laptop looks like its going to have to be a full lower manifold change. Ffs. Hope the injectors are all the same as I've had these overhauled.
40inches
posted on 23/6/19 at 09:59 AM Reply With Quote
This is the rail I used eBay Item
sdh2903
posted on 23/6/19 at 10:24 AM Reply With Quote
Cheers Dave. I dont know if its camera angles or if the lower manifold with the steel rail looks thinner? than the one with the plastic rail aswell.
40inches
posted on 23/6/19 at 11:29 AM Reply With Quote
The steel rail is thinner and much lower profile.
sdh2903
posted on 23/6/19 at 11:30 AM Reply With Quote
Have just offered up the inlet (with fuel rail removed) and I'm still probably a 25mm spacer short.
Jaginlet5
Jaginlet5
Having seen the pics of kevs build up his lower inlet looks a bit thicker. Have measured up the lower inlet and I have a depth of around 47mm. If anyone has the type of lower manifold with the metal fuel rail could you by any chance measure its thickness to compare?
Jaginlet6
Jaginlet6
sdh2903
posted on 23/6/19 at 11:31 AM Reply With Quote
I was meaning the lower manifold itself Dave. Sorry it wasnt very clear.
40inches
posted on 23/6/19 at 12:03 PM Reply With Quote
I have just measured my spacer and it is 30mm, that gives me 30mm clearance to the highest part of the steel fuel rail
from the manifold. So a 15mm spacer would give 15mm clearance.
I will see if I can measure the lower inlet. my engine is a 2001.
40inches
posted on 23/6/19 at 12:15 PM Reply With Quote
As near as I can tell the lower manifold is 50mm high.
sdh2903
posted on 23/6/19 at 12:31 PM Reply With Quote
Thanks Dave. And apologies for taking over your dyno thread
<<  3    4    5    6    7    8    9  >>
