New Topic New Reply
Author: Subject: Stupid locknut question
jps
posted on 1/3/19 at 08:39 AM Reply With Quote
Sorry this is probably a really silly question - but I will ask it anyway.
On my rear suspension I have a top wishbone/upright join that is made as T shape - an m20 threaded section bolts into an m20 thread in the wishbone (no insert- it's a fixed part of the wishbone) and a polybushed bracket attached onto the upright.
I want to put a locknut against the m20 thread to stop any slop from the thread - so expect to use an m20 halfnut. But will it still 'lock' if I put a washer between the wishbone and the nut - just to stop the halfnut scuffing off the end of the threaded section in the wishbone?
OR
Do i need a washer and then two halfnuts - so the wishbone doesn't scuff and the two halfnuts tighten against each other to provide the 'lock'?
posted on 1/3/19 at 08:49 AM Reply With Quote
Think I would use 2 myself , that’s how mainstream manufacturers would do it
40inches
posted on 1/3/19 at 09:07 AM Reply With Quote
I have a bag of M20 Nylock nuts if you want one?
jps
posted on 1/3/19 at 09:19 AM Reply With Quote
Thanks for the offer - i'll check there's enough space and will pm if there is!
posted on 1/3/19 at 09:21 AM Reply With Quote
MK supplied 2 nuts for this on the MK Indy i built...
mcerd1
posted on 1/3/19 at 10:38 AM Reply With Quote
^^ yes nuts really need to lock against each other - but half nuts are not structural and can't be used without a full nut
sounds like a Nylock is your answer though - thats what most suspension bolts seem to be anyway
just make sure you have enough length to get a min of 1 full thread sticking out
alternatively you could use lockwire or wedge type lock washers ( linky ) might work - but both have to be done a very specific way or they don't work....
[Edited on 1/3/2019 by mcerd1]
coyoteboy
posted on 1/3/19 at 02:04 PM Reply With Quote
What about a locknut and a nordloc washer?
Report your local potholes, it actually works!
Bluemoon
posted on 1/3/19 at 02:14 PM Reply With Quote
As this but added wire lock to one of them, so they are captive.... I don't like the idea of them coming loose
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
Slimy38
posted on 1/3/19 at 10:01 PM Reply With Quote
I do like their promotional video;
https://www.youtube.com/watch?v=IKwWu2w1gGk
It definitely highlights why Nylocs are (second) preferred. And while Nordlock come out on top, nylocs are far cheaper.
[Edited on 1/3/19 by Slimy38]
New Topic New Reply
