Author: Subject: Sierra rear left hub nut
flak monkey
posted on 22/3/19 at 04:40 PM Reply With Quote
Anyone have a spare LH rear hub nut kicking around? LH thread
Sera
https://www.facebook.com/sera.jay666
posted on 22/3/19 at 04:47 PM Reply With Quote
Bearing kits sometimes come with new nuts if your changing them. If you get stuck I may have a used one if I can find it?
flak monkey
posted on 22/3/19 at 04:56 PM Reply With Quote
I'm fed up with buying and returning bits - ordered bearing kits, twice, for the correct side of the car, both came with RH nuts.
I'm happy with a used one, loctite works wonders.
Sera
Kev99
posted on 22/3/19 at 05:17 PM Reply With Quote
https://www.ebay.co.uk/itm/2X-Wheel-Hub-Nut-fits-FORD-SIERRA-FEBI-06242-RH-06243-LH/202626615833?hash=item2f2d7cca19:g:sSAAAOSwH6lcjNoF
[Edited on 22-3-19 by Kev99]
flak monkey
posted on 22/3/19 at 05:22 PM Reply With Quote
Those are for the front - M27 thread.
Rears are M22.
Another source of much confusion
Sera
jps
posted on 22/3/19 at 05:44 PM Reply With Quote
I've definitely got some old ones lying around from a disc setup. Is the thread the same on the drum brake driveshafts?
posted on 22/3/19 at 05:59 PM Reply With Quote
Iíll have a look tomorrow if I get a chance .
40inches
posted on 22/3/19 at 11:35 PM Reply With Quote
I fitted a rear bearing about 2 months ago. The kit came with both left and right handed nuts.
Simply Bearings part number FBK085
posted on 23/3/19 at 01:13 PM Reply With Quote
Found it , let me have your details iíll Get it in the post on Monday.
chris
posted on 24/3/19 at 03:22 PM Reply With Quote
GBS sell the nuts but a bit pricey
posted on 25/3/19 at 10:26 AM Reply With Quote
In the post.
Mopple
posted on 25/3/19 at 10:28 AM Reply With Quote
https://caterhamparts.co.uk/driveshafts/4029-nut-driveshaft-lh-de-dion.html?search_query=hub+nut&results=128
