Author: Subject: Zetec silvertop compression test
AlexXtreme
posted on 23/3/19 at 10:09 PM Reply With Quote
I have been putting putting off testing the compression on my 1.8 silvertop for some reason. Had a slight misfire when cold and had a feeling that it was something serious. .. so did not want to find out it was something serious!
Anyway I have 2 cylinders at 165psi and 2 at 170psi with a slightly loose compression tester (with poor the adapter I could not tighten it up on each cylinder). No idea on how many miles the engine has done. I think around 50k.
Does this sound OK? The engine had been run but had stopped around 45mins before I tested the compression.
posted on 24/3/19 at 07:17 AM Reply With Quote
I wouldnt be concerned with those figures but I had a Zetec engine with a lumpy idle that had had the compressions tested several times, passed emissions test etc that when tested with a cylinder leakage tester showed a burnt inlet valve.
perksy
posted on 24/3/19 at 09:07 AM Reply With Quote
The readings are within 10% of each other which is good
Leakdown is the best way of testing
Test should really be done with a wide open throttle and with an engine at normal operating temp
AlexXtreme
posted on 24/3/19 at 09:19 AM Reply With Quote
It was wide open throttle though it had cooled a bit as I could not find the adapter for the compression tester in my garage..
My thought was as there was little difference between the values the slightly lower than expected was due to the temperature rather than anything else.
perksy
posted on 24/3/19 at 09:26 AM Reply With Quote
To be fair as their within 10% of each other I wouldn't be worrying
Is the Zetec on carbs or injection?
You've already checked plugs & leads?
In a previous thread you mentioned moving the Coil pack, Have you done this and are you happy with the wiring etc ??
[Edited on 24/3/19 by perksy]
AlexXtreme
posted on 24/3/19 at 12:15 PM Reply With Quote
Built leads from scratch and measured resistance so know they OK. Plugs are pretty new and adjusted.
Carbs (twin webers) and after re-balancing them, the tickover seems now OK. Why do they go out so quickly and it is always the same pair :-0?
falcor75
posted on 24/3/19 at 12:47 PM Reply With Quote
165 and 170 are close enough to not be an issue. Do a leakdown test, even if the engine is cold you can identify potential leaks. Found a crooked exhaust valve on the #3 cylinder on one of my aircooled engines that way.
AlexXtreme
posted on 24/3/19 at 01:09 PM Reply With Quote
I won't be doing this now but for my information, how do you do a leak down test without an air compressor?
posted on 24/3/19 at 03:11 PM Reply With Quote
If it is a Silver Top misfire from cold start can be due to hydraulic tappet jacking especially in cold weather. They are very sensitive to oil grade.
[I] What use our work, Bennet, if we cannot care for those we love? .
posted on 24/3/19 at 04:30 PM Reply With Quote
It can be done with a 12v tyre inflator as long as it is a heavy duty one usually sold as "4x4" or suitable for "off road"
The leakdown tester I now use is an AM Pro brand it wasn't expensive from eBay these days I tend just to do a cranking compression test with an oscilloscope.
