Author: Subject: Sierra tran-x problem
gaz_gaz
posted on 25/3/19 at 02:40 PM Reply With Quote
I have a sierra diff case with tran-x plated diff installed.
The drive flanges have been modified to take snap rings to the tran-x dimensions but near side shaft is bottoming out before the snap ring "snaps" into place.
Just wondering If anyone else has come accross this issue?
[Edited on 25/3/19 by gaz_gaz]
mcerd1
posted on 25/3/19 at 08:22 PM Reply With Quote
are both of the drive flanges the same length ?
posted on 25/3/19 at 08:45 PM Reply With Quote
Try changing side to side?
gaz_gaz
posted on 25/3/19 at 08:49 PM Reply With Quote
yes both flanges are the same length.
tried swapping side to side earlier and the problem remains.
Going to send the diff back to where it was rebuilt and see if they can work it out.
posted on 26/3/19 at 05:27 PM Reply With Quote
Seems a good idea to return it to source and ask them to look at it. Let's hope they can resolve it for you.
gaz_gaz
posted on 26/3/19 at 07:04 PM Reply With Quote
the diff is out the car and on its way back with parcelforce.
