Author: Subject: Thread repair
joneh
posted on 28/3/19 at 10:06 AM Reply With Quote
Thread repair
Morning all,
I have a stripped engine mount thread on a crossflow block. Only noticed it after finishing the rebuild - rookie mistake.
Whats the best method of fixing this, being cast iron? I'm thinking an m8 tap as its slightly bigger than 5/16 UNC? The bolt spins freely so I assume I can't use an original size tap. If that doesn't work can I helicoil it by hand?
Jon
posted on 28/3/19 at 10:47 AM Reply With Quote
Personally I would get a Helicoil repair kit and do a proper job. You never know , you may need it again . Failing that find someone with one? Iíve lost count of the times incorrect fittings have caused me problems.
joneh
posted on 28/3/19 at 11:10 AM Reply With Quote
Sounds the right approach. Is that easy to do by hand into cast iron?
posted on 28/3/19 at 12:22 PM Reply With Quote
If you can drill a hole straight and start a tap straight then it's a piece of cake.
posted on 28/3/19 at 01:08 PM Reply With Quote
As Mike says really, only thing I would add is use plenty of lube when drilling and tapping. Drilling and tapping fluid from Toolstation is cheap
steve m
posted on 28/3/19 at 04:26 PM Reply With Quote
I helicoiled all my crossflow mounts to 8mm, as the old 5/16th threads were manky
helicoil kits are easy to use, and once bought, used them loads of times
steve
907
posted on 28/3/19 at 07:54 PM Reply With Quote
I would drill it out to 8.5 mm and tap M10. Drill the mount 10.5 mm
Member of the Suttol Owners Club, and the BMMC
joneh
posted on 28/3/19 at 10:02 PM Reply With Quote
Thanks all, the hole is pretty beat up, so might have to go to 3/8 unc or m10. Will take a look tomorrow.
Jon
