Author: Subject: Fitting Sierra push in shafts
JekRankin
posted on 14/4/19 at 08:00 PM Reply With Quote
Just a quick one... when fitting Sierra push in shafts to the diff, are the half shafts meant to 'click' into position? Mine don't seem to want to do this, and just slide freely in and out on the splines.
Jek
jossey
posted on 14/4/19 at 08:09 PM Reply With Quote
That's how mine are I don't think they should click. They are held in by the uprights
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
posted on 14/4/19 at 08:54 PM Reply With Quote
Don't remember them clicking into position in the diff or the hubs. IIRC it's the hub nut that holds them in place. IIRC the torque figure for the nuts is quite high as well.
I also recall that the near side and off side drive shafts are slightly different lengths as well so take care when fitting them. If you look at the diff from above or below you'll see it's offset to one side.
big-vee-twin
posted on 15/4/19 at 08:21 AM Reply With Quote
Just slide in the cv's compress too, hub nut is 250NM torque.
http://www.triangleltd.com
minitici
posted on 15/4/19 at 05:04 PM Reply With Quote
The push-in inner CVs on the Sierra shafts do not have any locating circlips.
The shafts/CVs are just held in by the springs inside the tripod CVs pushing against the shaft.
[Edited on 15/4/19 by minitici]
