Author: Subject: IVA failed
Paul TVR
posted on 8/5/19 at 09:41 PM Reply With Quote
IVA failed
Minor fail on my GBS, few points picked up.
Fuel pipes insecure, over rear diff, couple of brackets made now.
Rear brake line could hit the driveshaft, added a p clip.
Light switch edge radius didn't conform, new one printed
Headlights don't meet the 45 degree visibility, printed a spacer.
Indicators only 320mm not the 350mm needed.
Dash bottom radius does not conform, was bought from kit car direct so a bit annoyed at that one, need a solution before I can book the retest.
loggyboy
posted on 9/5/19 at 12:25 AM Reply With Quote
Good fail with some fairly easy fixes.
What dash panel was it?
Paul TVR
posted on 9/5/19 at 06:47 AM Reply With Quote
http://www.kitcardirect.co.uk/westfield-wide-body-dashboard-panel-carbon-fibre.html
That was the dash panel.
Daf
posted on 9/5/19 at 08:14 AM Reply With Quote
How far off the radius was the dash panel? I had a similar one and covered it with this:
https://www.ebay.co.uk/i/153335163393?chn=ps
then a layer of vinyl over the top, the added thickness gave me the radius - it can all fall off after the IVA naturally!
CosKev3
posted on 9/5/19 at 08:18 AM Reply With Quote
Dash just needs some edging trim?
TBF it doesn't state its IVA compliant in the advert,so really its down to you for not checking before the test.
40inches
posted on 9/5/19 at 08:49 AM Reply With Quote
The IVA compliant one is This one
Paul TVR
posted on 9/5/19 at 05:53 PM Reply With Quote
The guys at kitcardirect have been pretty decent, it did say IVA compliant when I bought it and they have said they will help sort out a solution for me.
Paul TVR
posted on 20/5/19 at 03:27 PM Reply With Quote
Now a pass
Passed the IVA this morning, the guys were very reasonable at Southampton and mostly happy with the mods I did to get it through, although had to cut down the light switch.
Now have to fill out the registration forms, can they be submitted online to the DVLA or only via post?
mackei23b
posted on 24/5/19 at 02:06 PM Reply With Quote
Hi there
Just going through the same process.....post only as some of the documents need to be originals
Remember to visit: https://www.gov.uk/vehicle-registration/kitbuilt-vehicles as I did not include a V627/1....error on my part as I just looked at the guidance for new vehicles as I had a certificate of newness.
Ian
gremlin1234
posted on 24/5/19 at 02:38 PM Reply With Quote
make copies before you send them, they don't return them all.
Paul TVR
posted on 30/5/19 at 10:43 PM Reply With Quote
Got my approval today with the numberplate certificate.
Should be on the road by the weekend!
posted on 31/5/19 at 05:42 AM Reply With Quote
Just in time for summer
adithorp
posted on 31/5/19 at 06:47 AM Reply With Quote
Nice one. Be careful out there.
http://jpsc.org.uk/forum/
pewe
posted on 31/5/19 at 02:42 PM Reply With Quote
Second that - other road users seem to be oblivious to low profile, rapid motors - almost as a bad as riding a bike!
Enjoy - weather's looking good...
Cheers, Pewe10
