Author: Subject: Viento rear wishbone bushes
MikeBaker
posted on 22/5/19 at 07:31 PM Reply With Quote
Hi all,
So my car failed itís mot on the rear wishbone bushes, is there a specific replacement or an easy fix for the play?
As always, any help is appreciated
Mike
posted on 22/5/19 at 08:21 PM Reply With Quote
Probably best to remove one suspension arm and measure the inside diameter and the width of the wishbone eye and order a complete set of bushes and more importantly a set of stainless steel crush tubes from one of the polybush suppliers? It may be the suspension bolts are not tightened due to the well known crush tube problem? Were the wishbone mounting brackets to wishbone bushes spaced out with washers as the mountings are wider than the bushes?
MikeBaker
posted on 23/5/19 at 08:00 AM Reply With Quote
Are there no technical specs?
Itís just one that has failed but the rest are advisory so may as well change the lot.
Is there a good supplier that make custom sizes that arenít ridiculously priced?
Not sure to be honest (built by my step dad, and he just said the need sorting) Iíll have to take it apart and have a look at it properly.
posted on 23/5/19 at 01:58 PM Reply With Quote
Iíve not seen or heard of any technical specs but Steve Lovelock got some new bushes for his Velocity, think the details may be posted on the forum? Wouldnít have thought Luego would have used anything that wasnít easily available?
40inches
posted on 23/5/19 at 02:04 PM Reply With Quote
If you do that, I have some MK bushes that I can measure for you.
OliilO
posted on 23/5/19 at 05:09 PM Reply With Quote
Mk dimensions are on the kitcardirect website.
I'd be interested in this as i've got a Mac#1 and the OD of the bushes are 32mm so larger than MK ones. I'm currently at a loss for where to find something suitable now Mac#1 no longer exist.
posted on 23/5/19 at 05:26 PM Reply With Quote
Suspension-bushes,co,uk shows dimensions
Five seconds on goggle
OliilO
posted on 23/5/19 at 05:42 PM Reply With Quote
Cheers. I'd limited my searches to kit car bushes rather than generic; obviously too narrow minded.
posted on 23/5/19 at 06:44 PM Reply With Quote
Like I pointed out remove one arm and measure the bushes, that way you will know which size you need .
http://www.locostbuilders.co.uk/forum/27/viewthread.php?tid=63426
Have a read of this , thereís loads more posts on the subject
MikeBaker
posted on 28/5/19 at 09:23 AM Reply With Quote
Thanks for the help guys.
Hopefully I will be taking the suspension apart tonight and this week, clean it up and get some measurements.
MikeBaker
posted on 28/5/19 at 05:39 PM Reply With Quote
Ok, so the wishbones on the drivers rear are off, before I took them off I mopped the bolts tights and no more play, so I may be able to get it through itís Mot, but while the stuff is off I may aswell measure.
So I have some digital vernier callipers... whatís the best way to measure and what measurements do I really need?
posted on 28/5/19 at 05:58 PM Reply With Quote
Measure the outer diameter of the bush and also the wishbone , the width of the wishbone eye, the width of the chassis brackets although they are likely to be wider than the wishbone and bushes assembled the gap can be used to adjust various settings using stainless repair washers . Also measure the dia of the fixing bolts and the width of the assembled arm and bushes to allow you to get the correct length crush tube which ideally would be stainless. Have a search on here for crush tubes and associated issues. Ideal time to set up the castor
MikeBaker
posted on 28/5/19 at 06:19 PM Reply With Quote
The chassis brackets all seem to be the same size 42.31mm (however I could be wrong)
And I definitely donít have time to take all them measurements! So Iím just gonna nip the bolts and nuts up until there is no play and the wishbones still move.
posted on 28/5/19 at 07:11 PM Reply With Quote
If the bolts are all loose itís possible the original builder didnít tighten them to the correct torque as in the link I posted due to the well known crush tube issue
MikeBaker
posted on 28/5/19 at 07:59 PM Reply With Quote
Quite possibly!
Although Iím quite surprised there are no actual specific sizes out there considering the known issue?
I may have made them a little too tight, but itís to get it through the MOT and I can faff with it over winter as I want to powder coat the wishbones a diff colour.
MikeBaker
posted on 28/5/19 at 08:30 PM Reply With Quote
I canít seem to find the Luego Viento listed?
posted on 28/5/19 at 08:36 PM Reply With Quote
Thatís why you need to measure the ones you have.
MikeBaker
posted on 28/5/19 at 09:41 PM Reply With Quote
Ahhhh I must have misinterpreted what you actually meant.
