Author: Subject: Questions regarding bolt-on hubs
mi2jaca
posted on 11/6/19 at 06:38 AM Reply With Quote
I am looking into building my own locost(ish) running gear and plan on using bolt on hubs from an Vauxhall Astra (VKBA 5311) and making custom uprights.
I have been reading up on the forum, particularly this discussion regarding “New Locost front end design” (http://www.locostbuilders.co.uk/viewthread.php?tid=34017) but I am not getting any further.
So my basic questions are:
• Has this been done before?
• Any threads/links for more info?
• Is it possible to use the same hubs on all four corners of the car? In the front without CV joints. The bearing assemblies are gen 3 so they should be self-supporting?
//Carl
Carl Blomén
Writing from Gothenburg in Sweden
When in doubt - Go fast
adithorp
posted on 11/6/19 at 01:20 PM Reply With Quote
Yes they'll work fine on front without CVs in them. Plenty of tintops have gen3 bearings that way on the rear. GBS are doing that on their kits now and I think AB Performance are as well.
[Edited on 11/6/19 by adithorp]
http://jpsc.org.uk/forum/
ettore bugatti
posted on 11/6/19 at 09:24 PM Reply With Quote
TVR used it too on the Cerbera onwards and actually Lotus used GM bolt-on bearings on the S2 Elises, IRC they just used an M12 bolt to replace the drive shaft.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ettore+bugatti 's Aim   ettore+bugatti 's ICQ status This User Has MSN Messenger   ettore+bugatti 's Yahoo
Camber Dave
posted on 12/6/19 at 07:39 AM Reply With Quote
What Etore said
Quote
"IRC they just used an M12 bolt to replace the drive shaft."
Later Lotus upgraded M12 to an M16 with thick profiled washers.
mi2jaca
posted on 12/6/19 at 08:42 AM Reply With Quote
Thanks for the input guys. Much appreciated!
I could use a bolt like suggested, just to be on the safe side, but it should not really be needed should it?
Carl Blomén
adithorp
posted on 12/6/19 at 09:38 AM Reply With Quote
No, gen3 type bearings don't need a bolt through them. GM and others are using them that was.
[Edited on 12/6/19 by adithorp]
pigeondave
posted on 12/6/19 at 06:34 PM Reply With Quote
I think it was Saab hubs that had the same PCD as ford wheels and weren't massively heavy.
Although I heard that you might need to machine the centres down to fit ford wheels.
If someone knows of a bolt on hub with a sensor built in (which has a ford pcd) please let me know.
Im talking 4 stud here.
