Author: Subject: Wanted... Blacktop head.
furryeggs
posted on 12/6/19 at 10:10 AM Reply With Quote
Iím after a 2.0 blacktop head for my ST turbo build. Its on a locost budget so needs to be serviceable with cams.
can collect within 40 miles of LE14 or arrange courier.
whats about?
big_wasa
posted on 12/6/19 at 06:52 PM Reply With Quote
Have you got an St head ?
I may be up for a swap, Iíve already fitted the st inlet valve springs and tested it.
furryeggs
posted on 12/6/19 at 07:13 PM Reply With Quote
i have a complete head, inlet and exhaust, most of the loom, g/box and every other bit off the engine that the guy i bought it off couldnít be bothered to remove .
big_wasa
posted on 12/6/19 at 07:31 PM Reply With Quote
Yes the bits arenít worth a lot. I sold my st heads, one only made a pound
Donít underestimate getting all the bits in a 7. The turbo is the easy bit.
furryeggs
posted on 12/6/19 at 07:48 PM Reply With Quote
Up for a swap if you decide to...
Iíve taken a lot of measurements and started to plan the layout. Should be able to make it all fit?
big_wasa
posted on 12/6/19 at 07:58 PM Reply With Quote
Yep,
Have you taken yours to bits yet ?
furryeggs
posted on 12/6/19 at 08:41 PM Reply With Quote
everything is off apart from the timing belt and head...
