New Topic New Reply
Author: Subject: MX5 engine fitting using the OEM mounts
Slimy38
posted on 13/6/19 at 07:44 AM Reply With Quote
I'd like to fit my MX5 engine using the standard engine mounts, they seem quite sturdy and they are very 'locost' IE free with the donor. Reading one guide related to the MX5 suggest that these engine mounts are operating in shear (if that's the correct way to describe them), and it would be better to replace them with more 'typical' mounts such as Landrover ones. But surely they were working the same in the original car so it can't be a bad design?
Is there actually any issue with using the standard mounts? Has anyone actually used them and had any issues?
miskit
posted on 13/6/19 at 08:18 AM Reply With Quote
I use them on my sandrail engine swap - that gets a lot more abuse than a road car is likely to see (they are mounted properly just an odd camera angle!), 2k later no issues.
[Edited on 13/6/19 by miskit]
pewe
posted on 13/6/19 at 10:51 AM Reply With Quote
Locost tip for firming up the standard engine mounts - fill the cavities in the rubber with silicon sealant, leave to set for 24hrs - job's a good 'un!
Cheers, Pewe10
JAG
posted on 14/6/19 at 10:55 AM Reply With Quote
I also used the original Mazda engine mounts for my MX-5 engine installation.
They work fine - if Mazda engineered them they will work perfectly for our cars.
Just make sure that you mount them at the same angle that Mazda used.
Justin
ianhurley20
posted on 14/6/19 at 09:17 PM Reply With Quote
No photos sorry but used all MX5 engine mounts on my car and worked fine for me
Slimy38
posted on 15/6/19 at 11:09 AM Reply With Quote
Thank you all, looks like I'm ok sticking with my original plan. When I see one article saying they're bad, and then half a dozen (and the original car manufacturer!) saying they're ok, it's a pretty easy decision.
JAG, thanks for the pointer about keeping them the same angle, I am planning to mount them to the engine and build up the frame to meet them.
GR124
posted on 18/6/19 at 06:14 AM Reply With Quote
this is what I did, just to give you an idea of options
New Topic New Reply
