Author: Subject: ST200 Upper Inlet Manifold
Badger_McLetcher
posted on 17/6/19 at 05:35 PM Reply With Quote
As per the title really - I'm looking for a ST200 upper inlet manifold
If disfunction is a function, then I must be some kind of genius.
40inches
posted on 18/6/19 at 07:49 AM Reply With Quote
This one? eBay Item
You will need to blend the ports anyway
Or this one eBay Item
[Edited on 18-6-19 by 40inches]
Badger_McLetcher
posted on 18/6/19 at 06:58 PM Reply With Quote
Originally posted by 40inches
This one? eBay Item
I thought the bore of the runners was different between the ST24 (or standard Cougar v6 etc. inlet) and the ST200? I've ordered up a ST24 one with the thought that I could mock it up with that and swap it out later, but if the only difference is the ports I'm not sure it's worth getting an ST200 one any more!
Ben
Edit: Scrub that, just seen the post on the other thread. Looks like the ST24 ones are quite a lot smaller, so an ST200 would be a good upgrade
[Edited on 18/6/19 by Badger_McLetcher]
