Author: Subject: Rollcage mounted centre mirror (IVA)
G13BLocost
posted on 23/6/19 at 08:41 PM Reply With Quote
Hello,
As the title says- has anyone passed IVA with a rollcage mounted centre mirror and what make did you use? I have been using a longacre for trackdays etc but the radi on the mounts is a no go. Maybe weld up my own mounts?
Thoughts please,
Josh
My Locost blog: ogilvietacing.com
furryeggs
posted on 24/6/19 at 03:44 PM Reply With Quote
Take some rubber U seal and cut one leg off, loosen the bracket, tuck it under then tighten up. I passed with it like that.
loggyboy
posted on 24/6/19 at 03:55 PM Reply With Quote
Remember its checked in a forward direction only, so providing the fittings are behind the mirror they would not be contactable by the 165mm sphere
G13BLocost
posted on 24/6/19 at 05:57 PM Reply With Quote
Awesome! I can't remember if the centre mirror needs to be adjustable, but clearly not!
