Author: Subject: Identifying 2.0 Duratec
craig_thomas
posted on 8/7/19 at 05:17 PM Reply With Quote
Hi
Can someone tell me where I can find the engine code on a 2.0 Duratec please.
https://www.dropbox.com/sc/jpbrlzkq9z0n24a/AADJqF7KbolXtAu5NPlLjFlqa
obfripper
posted on 8/7/19 at 06:36 PM Reply With Quote
That's a crate ford power products duratec, there should be an engine code on the sticker on the rocker cover, likely DHE420.
It could have come from a caterham, morgan, westfield, or other small volume manufacturer.
The codes are unique to ford power products, and don't directly relate to factory fitted engine codes.
It would originally be supplied like this:
https://www.burtonpower.com/ford-built-2-0-duratec-he-i4-std-crate-engine-new-fd2000.html
Dave
big-vee-twin
posted on 8/7/19 at 06:51 PM Reply With Quote
On the bell housing flange stamped in.
http://www.triangleltd.com
craig_thomas
posted on 8/7/19 at 06:53 PM Reply With Quote
Thanks Dave
It is out of a factory built westy.
Do you think itís a i4 Engine then?
Dave
craig_thomas
posted on 8/7/19 at 06:55 PM Reply With Quote
https://www.dropbox.com/s/ddnkuj51b4q5lur/Photo%2008-07-2019%2C%2019%2054%2022.jpg?dl=0
obfripper
posted on 8/7/19 at 07:57 PM Reply With Quote
It looks to be the same engine as the burton's link (no cam phase sensor, ford commission plate), there's nothing to say what is done to the engine tuning wise, however 200bhp is do able with the right taper thottle bodies, exhaust and no other mods.
Dave
Originally posted by craig_thomas
Thanks Dave
big-vee-twin
posted on 8/7/19 at 08:31 PM Reply With Quote
It's not on the mating surface there is a flat with numbers stamped on you can still see it with box fitted.
[Edited on 8/7/19 by big-vee-twin]
