Author: Subject: wanted 42 / 42 tooth sprocket for open chain diff
doddy
posted on 21/7/19 at 10:46 AM Reply With Quote
hi im trying to get my sprocket set up correct has anyone got a 40 41 42 tooth sprocket for a open chain diff even a worn one just so i can get the right size before i buy new and its the wrong size its for my r1 mini van
[Edited on 21/7/19 by doddy]
http://stores.ebay.co.uk/Triple-S-Motorcycles/_i.html?rt=nc&_sid=73183733&_trksid=p4634.c0.m14&_sop=3&_sc=1
russbost
posted on 21/7/19 at 12:10 PM Reply With Quote
I may possibly have a 42 tooth, will have a look tomorrow, but surely exact size will vary according to what chain size it's made for?
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
doddy
posted on 21/7/19 at 07:36 PM Reply With Quote
i have a 530 chain on a Quaife ATB QDF14K chain lsd but i only have a 46 and 47 tooth which are way to far off
russbost
posted on 22/7/19 at 09:47 AM Reply With Quote
Just checked, sorry looks like the 42 tooth I had got binned, only thing I have is a 37 tooth which is 200mm across the diameter, point to point of the teeth. That was for a ZX10 chain which I seem to remember is also 530.
I normally use 46 tooth.
Just one additional thing to be careful of, never use a sprocket which has an exact multiple of the front sprocket size, eg 14 to 42, (3 : 1 gearing) it will give horrible resonance & rumble as you always get the same teeth coinciding with the same teeth on each sprocket
Mike Wood
posted on 22/7/19 at 09:26 PM Reply With Quote
Try Westgarage Engineering Services:
https://chaindrivediff.co.uk & http://www.westgarage.co.uk/index.html & http://www.westgarage.co.uk/calculators/calculators.html
Mike
