Author: Subject: GTS W7DE
westf27
posted on 27/7/19 at 10:11 AM Reply With Quote
GTS W7DE
Can anyone give the basics of the running gear for this model
Ie brakes steering gear rear transmission.
Roof and doors pah ! who needs 'em.......well not March/April or parts of October
big_wasa
posted on 27/7/19 at 04:55 PM Reply With Quote
I would think it’s the like the standard width Panther but the body is +4”.
It’s all Sierra, accept the steering rack which is mk2 Escort. T9 gearbox and Zetec where the popular option.
Unlike most kits Darren used a de-deion rear beam.
So the chassis was pretty much “Locost” with the rear bulkhead 25mm higher than book to match the 25mm higher nose, bonnet, scuttle. This gave extra room for a Zetec.
The chassis has the Sierra diff mounts but also the book style trailing arms and pan hard rod.
[Edited on 28/7/19 by big_wasa]
westf27
posted on 27/7/19 at 05:55 PM Reply With Quote
Thanks for that,informative and clear.
big-vee-twin
posted on 28/7/19 at 08:54 PM Reply With Quote
Have a look in my photos, I have the Panther.
http://www.triangleltd.com
Charlie_Zetec
posted on 29/7/19 at 10:32 AM Reply With Quote
I think it's based upon the McSorely +442 drawings, which makes it 100mm wider, 100mm longer, and 50mm taller than book dimensions.
Other than that, all appears correct. Can possibly get you some pics/dimensions at the weekend if you need them (and i can get to my unit)?
Tonesta
posted on 5/8/20 at 01:51 PM Reply With Quote
Hi I have a W7DE, it uses standard sierra parts however as the engine bay has a bit more room allowing you to fit in turbos superchargers etc lol.
If you need any advice or pics then I can help.
Tonesta
