Author: Subject: Is Odometer required for MOT?
Slater
posted on 12/8/19 at 05:41 PM Reply With Quote
Hello
My ETB digital odometer is blank most of the time. My MOT is due in October. Is the odometer mileage reading required to pass the MOT?
The unit is from 2007, I've called ETB, it can't be repaired, their suggestion is to remove it from dash and put somewhere warm with the bulbs removed to remove any moisture. This does seem to work but the odometer display is still very intermittent. The mileage is still counting up but mileage display is blank 95% of the time.
Don't want to fork out 166 for a new speedo if I don't need too!
gremlin1234
posted on 12/8/19 at 05:47 PM Reply With Quote
Originally posted by Slater Is the odometer mileage reading required to pass the MOT?
no, you don't have to have one for the mot
edit, don't need odometer for iva either
[Edited on 12/8/19 by gremlin1234]
Slater
posted on 13/8/19 at 09:23 AM Reply With Quote
OK thanks, that's good news.
I will carry on with my "intermittent" gauge for the time being.
MikeR
posted on 14/8/19 at 07:48 AM Reply With Quote
Are you sure about IVA? I was certain it was a requirement and I thought when sva was introduced people failed with bike Speedos due to not having an odometer
chillis
posted on 15/8/19 at 10:22 PM Reply With Quote
It is a Requirement of the IVA Section 17 Speedometer and reverse gear, a working and accurate speedometer must be present and a test is conducted to acertain its accuracy.
It is also a legal requirement for all motor vehicles to have both a working speedometer and a working odometer under construction and use. Motor vehicles must also have a fuel level indicator as it is an offence to enter a motorway knowing you will run out of fuel.
Never under estimate the ingenuity of an idiot!
posted on 16/8/19 at 07:14 AM Reply With Quote
I havenít tested for 3 years but when I was testing if the odometer didnít show a reading the mileage was shown as not recorded. There has however been changes since then , I donít know if odometer is one of them.
adithorp
posted on 16/8/19 at 09:24 AM Reply With Quote
Still not a failure on MOT. Took one this week with no reading on the digital odo'.
I thought the IVA issue with bicycle speedos was the lack of illumination not lack of Odometer.
http://jpsc.org.uk/forum/
MikeR
posted on 16/8/19 at 12:01 PM Reply With Quote
You could be right about illumination as I do remember thinking about how I could fit a light to a bike Diego that did record miles.
scimjim
posted on 20/8/19 at 06:54 AM Reply With Quote
It IS an MOT fail - but Iíve never seen one checked.
scimjim
posted on 20/8/19 at 06:57 AM Reply With Quote
Defect...................................................................Category
Speedometer not fitted where one is required.............Major
Speedometer:
operation impaired...................................................Minor
not working.............................................................Major
Speedometer:
not sufficiently illuminated.........................................Minor
not illuminated.........................................................Major
posted on 20/8/19 at 07:19 AM Reply With Quote
Speedometer:
Speedometer:
No mention of odometer!
scimjim
posted on 20/8/19 at 07:35 AM Reply With Quote
Sorry, I read speedo, not odometer :oops:
[Edited on 20/8/19 by scimjim]
