Author: Subject: Raceline sumps windage tray.... Any pics or info on this please?
Bamo
posted on 17/8/19 at 10:39 PM Reply With Quote
I've gone from a silver top to st170 and noticed my windage tray won't bolt up to the mains on the St engine as if fails the crank. I've since read raceline mount this to the sump? Has anyone got pics of this please and g he asurements? Thank you.
big_wasa
posted on 18/8/19 at 07:10 AM Reply With Quote
Mine's fitted so I can't help with pictures or dimensions but.
It simple bolts to the base tray with some spacers. The base tray has captive nuts fitted.
Bamo
posted on 18/8/19 at 08:00 AM Reply With Quote
Thanks again, I think I need to see if I can exchange/part ex mine as just took delivery of it. I thought Id be able to mount my silver top windage tray but it doesn't work the same, have different mains.
big_wasa
posted on 18/8/19 at 09:21 AM Reply With Quote
If you have just bought it then you probably only need the fitting kit ?
I bet the base plate is already cut for the captive nuts infact I would be surprised if there not already fitted.
big_wasa
posted on 18/8/19 at 09:27 AM Reply With Quote
There is one on Ebay that shows the captive nuts and there aftermarket windage tray. The silvertop tray should also fit.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F303244080683
[Edited on 18/8/19 by big_wasa]
Bamo
posted on 18/8/19 at 07:19 PM Reply With Quote
You're correct, just opened and new one just needs captive nus and windage tray, old one someone has butchered but was origional part didn't have these. Thanks again.
