Author: Subject: Crossflow - fouling 3 out of 4 plugs - any ideas
briarswood57
posted on 19/8/19 at 07:01 PM Reply With Quote
Hi there,
Looking for some help from the collective. Got 1660 Crossflow in the Westfield running on twin 40s. The car had been in hibernation for 15 or so years before I bought it - work done by me includes carb rebuild, new accuspark distributor, coil and leads. Itís all through an MOT but here is the problem - itís consistently sooting 3 out of 4 plugs within 20 miles. I would expect it running a bit rich but canít fathom out why it soots cylinder 1,2 and 4 but cylinder 3 is ok.
Idle is always a bit lumpy but past 3k revs it runs fine.
Any ideas what to check? Has anyone had a similar issue?
Thanks in advance.
posted on 19/8/19 at 07:16 PM Reply With Quote
Excessive fuel pressure ?, incorrect float levels ? jets etc , blockage ? worn pistons, rings ,bores , block breather ? Incorrect valve clearances ? Have you tried new plugs of the correct heat range? Carb balance?
[Edited on 19/8/19 by rusty nuts]
briarswood57
posted on 19/8/19 at 07:45 PM Reply With Quote
Hi there. Thanks for the ideas
Tried some of those - float levels checked when carbs rebuilt a few months ago, however Iíll check for blockages.
Carb balance I think is acceptable - I did it by ear so perhaps using a vacuum gauge - Iíll try that
Rings - I did a compression test which was equal across all cylinders and well within range. Worth doing a leak down test?
Plugs are the NGK BP7ES (3rd or 4th set this season) which I think are ok but happy to be corrected.
Iíll have a look at fuel pressure and valve clearances before I take the head off for a more detailed look at the bores etc. Thatís a job for bank holiday weekend:-)
Thanks again for the ideas.
perksy
posted on 19/8/19 at 08:01 PM Reply With Quote
Get the balance right first and then go from there
Might sound daft, but Have you checked to make sure the jets are all the same size etc?
How did you set the initial mixture strength up after rebuilding the carb's?
posted on 19/8/19 at 08:06 PM Reply With Quote
Before taking the head off do a compression test when the engine is hot and throttle fully open the put a few squirts of oil into each cylinder and recheck compressions . Does the engine reach normal operating temperature?
AlexXtreme
posted on 20/8/19 at 08:23 AM Reply With Quote
Agree comments above, get the carbs balance right first before trying other options.
I brought a simple flow meter and which made it much easier
[Edited on 20/8/19 by AlexXtreme]
posted on 20/8/19 at 08:48 AM Reply With Quote
It's possible they are all jetted the same (but incorrectly) and you have an air leak on one cylinder. If you are using Misab plates and the compliant rubber or Thackery washers on the bolt, then check this all very carefully since air leaks are pretty common.
briarswood57
posted on 20/8/19 at 10:58 AM Reply With Quote
Thanks for the suggestions - all good areas to explore - its helpful getting some differing views to help prioritise.
I think the order of priority is:
1) Do a hot compression test as suggested - if that indicates other issues then I might need to think again, howerver assuming compression is Ok then move onto:
1) Confirm jets are all the same size - apparently the carbs were re-jetted with the original owner, however now I think about it he did mention something about passing on a box of jets - might be some got switched
2) Double check for leaks - when I rebuilt the carbs I put a new MISAB plate and thackery washers on but worth checking again
3) Balance the carbs so I'll get onto the internet and get myself a carb-balancer (unless anyone here has one going cheap?)
4) Check valve clearances.
I think thats probably a sensible order to start with over the BH weekend and see if that sequence improves things.
On a related note - my understanding of the DCOEs is that the only "dynamic" adjustment is the idle screw which is used to set the idle and balance the carbs. All the other adjustments would be by replacing jets?
Thanks again for the input.
posted on 20/8/19 at 11:51 AM Reply With Quote
Check and adjust the valve clearances before attempting to do anything with the carbs, you wonít be the first to get caught out by tight valves . Trying to set carbs should only be done after valves, timing etc have been attended to .
gremlin1234
posted on 20/8/19 at 11:54 AM Reply With Quote
don't they also have a choke control?
briarswood57
posted on 20/8/19 at 01:01 PM Reply With Quote
No choke control on mine - in as much as there is no choke to pull on. I assumed mine had the choke delete kit, however just had a look at the net and now not so sure....... something else to investigate.
Next stupid question - should I set valve clearance hot or cold.
Thanks again.
posted on 20/8/19 at 02:04 PM Reply With Quote
Valveclearances should be set according to the camshaft manufacturers settings ,probably cold though , what cam does it have as the settings may not be as standard?
AlexXtreme
posted on 20/8/19 at 02:18 PM Reply With Quote
with these carbs you should not need a choke anyway as you will flood the engine..!
I would have thought the clearances would be as standard as the gap is to take account of the expansion as the components heat up ... that is just my suggestion though as others might now better
briarswood57
posted on 20/8/19 at 03:00 PM Reply With Quote
I believe itís a 234 Kent ďfast roadĒ. I can see the clearance values on the Kent website so
Iíll have a go at that tonight. It didnít specify hot or cold but Iíll go for cold.
Thanks again.
posted on 20/8/19 at 05:22 PM Reply With Quote
While your at it make sure that all the valves open properly, wouldnít be the first camshaft to have worn lobes.
briarswood57
posted on 23/8/19 at 08:40 AM Reply With Quote
Thanks again.
briarswood57
posted on 23/8/19 at 06:13 PM Reply With Quote
Thanks for all the help so far. Quick update - valve clearances seemed a good bit out - fairly tight so have readjusted as per Kent Cams spec, however just picked up a cheap DTI from Amazon and going to check valve lift etc and reassure myself it is indeed a 234 cam before I go any further.
AlexXtreme
posted on 24/8/19 at 05:06 PM Reply With Quote
my money is on the carb balance :-)
