Author: Subject: Thought / Requirements On Tank Breathers
the_big_1
posted on 13/9/19 at 08:49 AM Reply With Quote
Hi guys,
a lot of talk on many threads about what breathers etc to use for the fuel tank breather.
Reading the IVA, it only really mentions:
"The fuel tank must be fitted with a vent (to permit release of a pressure build up) which does not exit on to the exhaust or into the vehicle or be situated at such a height that fuel would be likely to leak when the vehicle is driven."
So from this, I would think that a simple one way, roll over valve like this
https://www.carbuilder.com/uk/fuel-roll-over-valve-6mm
And a filter like this, positioned high up in the rear section
https://www.ebay.co.uk/itm/Pit-Dirt-Quad-Bike-fuel-cap-breather-pipe-gold/254162497296?hash=item3b2d43ef10:g:~EwAAOSw5cNYQy46
What are your thoughts?
big-vee-twin
posted on 13/9/19 at 10:23 AM Reply With Quote
I have used one of these inserted into a length of pipe with an air breather filter on the end, no issues so far.
https://www.demon-tweeks.com/uk/atl-tank-vent-valve-6-vent-inline-to-suit-6-hose-3-8-hose-barb-atltf-af-004/
http://www.triangleltd.com
the_big_1
posted on 13/9/19 at 10:45 AM Reply With Quote
My pipe is all 8mm
also, does that contain a one way valve, hard to tell?
posted on 13/9/19 at 11:21 AM Reply With Quote
On my MK Indy I didn't fit a one way breather, simply a length of fuel hose that ran down the side of the fuel tank to below the base of the tank. It prevented any pressure build up inside the fuel tank and had the car gone upside down it would have done the same without allowing fuel to drain out of the tank (assuming the tank hadn't been punctured).
Passed SVA without an issue - I've not IVA'd a vehicle so I'm not familiar with what the current rules may or may not be.
theconrodkid
posted on 13/9/19 at 11:52 AM Reply With Quote
the tank needs to vent both ways as when fuel is burnt, the tank would implode / engine suffer from fuel starvation, easiest way is a length of brake pipe with a coil wound into it a bit above the tank and exiting into the air near the chasis bottom rail.
who cares who wins
pass the pork pies
View User's Profile E-Mail User View All Posts By User U2U Member   theconrodkid 's Aim   theconrodkid 's Yahoo
ttalps2000
posted on 13/9/19 at 12:29 PM Reply With Quote
drill a small hole in the fuel filler cap..... only needs to be 0.5mm if that!
pekwah1
posted on 13/9/19 at 02:13 PM Reply With Quote
As Nick205 has done, i've just run some rubber tube up and back down, passed IVA like this and never had a problem
40inches
posted on 13/9/19 at 04:36 PM Reply With Quote
Same here
the_big_1
posted on 13/9/19 at 05:24 PM Reply With Quote
Guess I could run a pipe up and back down and fit the filter end on too
scimjim
posted on 13/9/19 at 08:33 PM Reply With Quote
Or buy a vented cap
