Author: Subject: ST170 VVT control
lewis
posted on 24/9/19 at 11:59 AM Reply With Quote
ST170 VVT control
I have a ST170 to replace my zetec 1.8 , Iím looking for a way to control the VVT there was a aftermarket controller made by ME but they donít sell it anymore.
My question is what are my options? Iíd like to use it so donít really want to delete it. Iím using a Specialist Components Typhoon 2 ECU & donít want to completely replace my ECU system.
Any help is appreciated
I am a driving god!..........sort of
Nickp
posted on 24/9/19 at 01:39 PM Reply With Quote
I believe that Trigger Wheels bought the VVT Pro from ME - http://www.trigger-wheels.com/store/contents/en-uk/p275.html
I picked up a 2nd hand one for my ST170. Worked a treat and made a massive difference to the way it ran, smooth from tickover and pulled really hard right to the redline. I was on ZX6R carbs and it made 178bhp with lovely smooth torque / power curves
lewis
posted on 24/9/19 at 03:06 PM Reply With Quote
I have looked into this & it was developed by M.E Looks like they donít stock/sell it anymore 😐 are there any other options out there to do the same job?
Barksavon
posted on 24/9/19 at 06:02 PM Reply With Quote
I think DANST Engineering do a package now which includes bike carbs, inlet manifold and a controller for ignition and VVT, it's around £1300 if my memory serves me well
Nickp
posted on 24/9/19 at 06:07 PM Reply With Quote
I used the original part of ST170 manifold that bolts to head £0
ZX6R carbs £40
Megajolt £80
VVT Pro £120
ZX6R fuel pump £20
Silicone hoses etc £30ish
Job done
lewis
posted on 24/9/19 at 06:54 PM Reply With Quote
Unfortunately the danst kit is still a ECU replacement,I wanted something I could run using my existing ECU as I did not want the hassle/expense of replacing the ECU/wiring
big_wasa
posted on 25/9/19 at 12:42 PM Reply With Quote
I don't think they where terribly reliable.
I wonder if the oem ECU could be cut down to make a budget controller. I am sure Me did something similar to emulate and read the map when designing it.
Nickp
posted on 25/9/19 at 12:49 PM Reply With Quote
Mine worked a treat when I fitted it but tbh I didn't keep the car long enough to comment on the unit longevity.
