Author: Subject: Rear calipers for solid discs
CNHSS1
posted on 8/10/19 at 01:28 PM Reply With Quote
Looking for a pair of brake calipers, to suit solid 240mm discs
Ideally alloy, 89/90mm mounting hole spacing, do not need handbrake facility as not for road car
What ya got? :-)
obfripper
posted on 8/10/19 at 04:13 PM Reply With Quote
I've got a pair of powerlites and m16 radial mount brackets, 4x1" pistons (eqv to 36mm single piston) and for solid 8-13mm thick discs.
I can dig them out if you want some pics and measurements.
I also have new m1144 pads to suit.
Dave
[Edited on 8/10/19 by obfripper]
CNHSS1
posted on 8/10/19 at 09:06 PM Reply With Quote
How much? 1144 may be a bit much for hillclimbs on the rear, work fine on the front though
Ill have a dig thru Wilwood catalogue for mounting specs :-)
