Author: Subject: RADIATORS FANS AND FILLER NECK WITH DISCOUNT
Coolexperts
posted on 8/10/19 at 02:44 PM Reply With Quote
Coolex are proud to be the suppliers of many of the racing Locost cars, We offer the Escort sized radiator with reversed side brackets and no filler neck
The radiator comes in 3 depth sizes, 42mm which is bigger that the standard Ford radiator, 55mm and 70mm.
There is a 10.00 voucher for Locost Forum member to use in the checkout basket FORUMRAD
http://www.coolexperts.co.uk/product-category/radiators/locost/
We now have a combination Thermostat housing filler neck that faces the top inlet on the radiator. This is designed for the Crossflow and Lotus engines
There is a 10.00 voucher for Locost Forum member to use in the checkout basket THERMONECK
http://www.coolexperts.co.uk/product/thermostat-housing-filler-neck-combination/
We also have a range of universal cutlass blade turbo fans available, fitted on welded brackets with a Lucas type fan operating switch in a welded boss.
http://www.coolexperts.co.uk/product-category/electric-fans/coolex-fans/
