Author: Subject: Fuel gauge options?
Petej
posted on 11/10/19 at 07:34 AM Reply With Quote
Fuel gauge options?
After some help/advice - have an MK Indy R1 and though I have low warning light on the R1 Clocks in an ideal world a fuel gauge would be handy, is there any option to add a sender unit to the tank or the fact one wasnít fitted when the tank was fabricated mean this is now not an option? If itís a huge effort Iíll make do.....
Pete
ChrisL
posted on 11/10/19 at 08:46 AM Reply With Quote
If you have a low fuel warning light on the gauge that suggests you have some kind of fuel level sensor. do you know what's already on the tank?
posted on 11/10/19 at 09:52 AM Reply With Quote
Did you use an MK supplied tank?
I did on my Indy and fitted the Sierra float sender to it. IIRC it had a hole already in the top and an internal baffle to prevent fuel slosh.
Petej
posted on 11/10/19 at 10:14 AM Reply With Quote
Cheers guys, Iím pretty sure itís an MK supplied tank yes, Iíve only had the car for a few weeks and currently on holiday so canít go and check, Iíll have a proper look when back and update on that.
Pete
big_wasa
posted on 11/10/19 at 12:15 PM Reply With Quote
Thre little koso mini 3 looks like a tidy add on.
