Author: Subject: Clutch pressure plate
johnnybizzle1986
posted on 1/12/19 at 09:58 AM Reply With Quote
Hi All
I have a lightened ginetta GT5 flywheel on my zetec engine, it has a 215mm friction plate but no pressure plate, I have tried to track one down was wondering if anyone could help.
The flywheel is 285mm standard diameter
3 pins at 218mm c/c between them
And has 215mm which fits my mt75 gearbox
Regards Jon
wonderfulweasel
posted on 1/12/19 at 12:56 PM Reply With Quote
Precision clutch components will be able to sort you out.
I've no association, but have had good service from them recently.
I'll post up their details later when I get home.
big_wasa
posted on 1/12/19 at 03:45 PM Reply With Quote
Has the flywheel got drillingís for extra locating pegs ?
215mm is a pinto size. If it has other holes for locating pegs it would suggest itís been redrilled for a pinto clutch.
Standard Zetec E is 220mm on the 1.8 and 240mm on the 2.0 and the 130ps 1.8 silvertops.
You can use a fwd clutch with the Mt75 but there is slightly less travel making the clutch a little on or of but not that bad.
With a fwd clutch and Mt75 there is a gap of 20mm between thrust bearing and clutch. Westfield glued a spacer to the thrust bearing. Iíve had two and they work fine. Gbs use a longer clutch pivot pin. Iíve also seen a few other solutions.
With a pinto clutch there will still be a shortfall but not 20mm.
kingster996
posted on 3/12/19 at 05:34 PM Reply With Quote
I have a light flywheel off a Ginetta on my Zetec. The pressure plate and clutch plate are off a mk1 Mondeo
One of these https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F333373738177
I used to be indecisive, but now I'm not so sure
johnnybizzle1986
posted on 3/12/19 at 07:52 PM Reply With Quote
Great stuff thanks, il get one ordered
kingster996
posted on 3/12/19 at 11:37 PM Reply With Quote
Not sure if it helps but hereís a pic of my Ginetta flywheel (weighs 3-4kg)
[Edited on 3/12/19 by kingster996]
