Author: Subject: Driveshaft length
sammini7
Contributor
Posts 36
Registered 14/8/17
Member Is Offline
Photo Archive Go!
Building: GTS Panther (Honda K20A + RX8 6 Speed G.Box)
posted on 10/12/19 at 07:45 AM Reply With Quote
Driveshaft length
Hi Guys,
I am building a Sierra based kit car and my differential is mounted in the centre and my driveshafts are equal in length. Every Kitcar I have seen has unequal driveshaft lengths. and the differential mounted off centre, I canít think from an engineering point of view it would make a difference and this is purely down to a engine/gearbox installation location .. as I donít have a builders manual and my expertise is in civil engineering not mechanical engineering, can one of you knowledgeable gents advise if Iím right.
Thanks in advance
posted on 10/12/19 at 11:38 AM Reply With Quote
The Sierra diff is slightly off-set to one side of the vehicle meaning the driveshafts are (or should be) unequal length. Although the diff may look as if it's mounyed centrally in the vehicle the actual outputs of it are not equally spaced around the centreline. I can't recall which side is the longer and which the shorter driveshaft (it's some years since I built and sold my Sierra based MK Indy).
I'm sure others on here will know which side is which.
voucht
posted on 11/12/19 at 07:20 AM Reply With Quote
If the mounting points of the diff are equally distant of the car's centre line (diff is centred), then you should have unequal length drive shafts. It is the case on the Haynes Roadster, which uses OEM Sierra drive shafts (unequal), and I guess number of Sierra based kit cars.
The reason is that a differential is not a symmetrical mechanism, as there is the large crown wheel on one side. This crown wheel takes space on one side of the diff, hence a shorter drive shaft on this side if the diff is perfectly centred.
If you have equal length drive shafts, the mounting points of the differential should not be equally distant of the car's centre line (diff should be off-centre).
In my humble opinion, it is one or the other, and it sounds a bit weird to me that drive shaft could have the same length with a centred Sierra differential.
Sylvain
http://vouchtroadster.blogspot.se/
motorcycle_mayhem
posted on 11/12/19 at 06:57 PM Reply With Quote
If your differential is mounted on the centre line, your left hand driveshaft will be shorter than the right.
Equal length driveshafts are found on cars where the differential is offset to the right, the engine (the only unit I've seen in the paddock so placed is a bike unit) then offset to suit. Looked good on a bike unit anyway, unsure how a car unit would suit.
Other ways of getting the driveshafts of equal length include an angular drivetrain installation, nice example of that in the chain drive world are the Speads cars.
It matters not, the only issues are the need to carry two shafts in the van to the circuit if it's an unequal installation. The only other (slight) issue is that the joints on the shorter shaft get a harder time in articulation.
