Author: Subject: Wtd MT75 gear lever remote bracket
r1_pete
posted on 19/12/19 at 08:04 PM Reply With Quote
Need the front bit which bolts to the gearbox.
I know a lot had the back 80 or so mm cut off to mount the lever ball socket to the chassis, I need the bit thats left if anyone has one kicking about.
big_wasa
posted on 19/12/19 at 08:58 PM Reply With Quote
Ive modified mine a few weeks back.
Do you mean just the bracket ? Your in luck.
Or
Complete with the cradle ? Your out of luck as I can not find it. Probably vanished with the rest of the scrap.
r1_pete
posted on 19/12/19 at 11:06 PM Reply With Quote
Its the cradle I was after, so I can drop it in the Scimitar, then set the gear lever position.
Think Im going to take your design, and adapt it so I can slip the stock nylon socket between two rails, set the position, then weld or bolt it in....
