Author: Subject: 4age installation parts
richwill
posted on 28/12/19 at 11:53 AM Reply With Quote
I’m looking to upgrade my Luego Velocity this winter by removing the pinto and fitting 4age 20v. I’m looking for parts to help with this. I have listed below what I need
Exhaust system
Ecu/ management
Wiring loom
Does anyone have any parts lying around or can point me in the right direction to get them.
JonBowden
posted on 28/12/19 at 02:47 PM Reply With Quote
not sure if this helps much but the 16 and 20 valve exhaust systems are very similar (except for one mounting hole being moved by a few mm).
I am planning to make my own using a flange plate from Danst engineering.
Jon
1960dave
posted on 29/12/19 at 11:30 AM Reply With Quote
I have a 16v exhaust manifold spare left over from my westfield conversion plus a 16v exhaust flange both in stainless.
JonBowden
posted on 29/12/19 at 01:19 PM Reply With Quote
Richwill, If you don't buy Dave's manifold, I might be interested
Jon
JonBowden
posted on 29/12/19 at 01:47 PM Reply With Quote
What are you doing for the gearbox, bellhousing and clutch?
Jon
richwill
posted on 29/12/19 at 01:54 PM Reply With Quote
Dave I would be interested in the manifold and plate. Please message me about price etc
richwill
posted on 29/12/19 at 01:56 PM Reply With Quote
Jon
I have a T9 gearbox with correct bell housing and clutch
1960dave
posted on 29/12/19 at 04:43 PM Reply With Quote
I am using a ford type 9 box with a Raw bellhousing ( Paul Woods of Woodsport has one for sale). I am using a aw11 flywheel with a aw11 clutch cover and a ford 2.0 pinto clutch plate. I did have a omex to run the timing and weber carbs
JonBowden
posted on 30/12/19 at 11:51 AM Reply With Quote
What do either of you use for the spigot bearing?
Jon
1960dave
posted on 30/12/19 at 12:14 PM Reply With Quote
I have a couple of spare bearings if you need one
