Author: Subject: Hayabusa cooling help
Nitrogeno25
posted on 7/1/20 at 02:52 AM Reply With Quote
Hi, I'm helping a friend with his Hayabusa gen1 engine. The car works fine on the road but on the track, after some trashing the water comes out from the header tank. We tried an electric water pump that seems to improve a little the cooling but the problem persists after some laps (always happend after some long straights flat out).
Compression test indicates the engine is fine, no problem with head gasket.
Temperature is about 93 for the water and 110 for the oil when the water is thrown away.
Any ideas?
Many thanks!!
[Edited on 7/1/20 by Nitrogeno25]
Nickp
posted on 7/1/20 at 07:16 AM Reply With Quote
Is the header tank big enough? ie Is there enough room for the water to expand before it forces past the cap?
Is the cap Ok?
jeffw
posted on 7/1/20 at 10:53 AM Reply With Quote
Got to be a cap issue I would think, sounds like it isn't pressurising the water system.
[Edited on 7/1/20 by jeffw]
Nitrogeno25
posted on 7/1/20 at 12:14 PM Reply With Quote
Originally posted by jeffw
Got to be a cap issue I would thing, sounds like it isn't pressurising the water system.
Cap was replaced twice, we also tried a higher pressure one.
I heard the cylinder head in the gen 1 Hayabusa has some hot spots where the water can boil...
Nitrogeno25
posted on 7/1/20 at 12:56 PM Reply With Quote
We even looked at the setup used in a Radical (same engine) and the Radical does not use an expansion tank, only a long tube with the cap.
At high temperature we sometimes see some bubles, but pressure testing does not shows any sing of head gasket failure.
russbost
posted on 7/1/20 at 01:19 PM Reply With Quote
My suspicion would be a very small head gasket to water jacket leak which probably shows up only when used hard. If you have access to a 4 gas (mot test type) analyser then just wafting it above the expansion bottle with the cap off should confirm whether there are HC's being released into the water
If the leak is small then perfectly possible that it will only go in the direction of gases into the water without any other symptoms, eg no water/oil mixing & no other obvious head gasket type problems
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
PumaWestie
posted on 7/1/20 at 07:34 PM Reply With Quote
Can you upload a sketch of the plumbing? Where does the bottom most feed from the header tank run to and where have you put the electric pump?
posted on 8/1/20 at 08:01 PM Reply With Quote
Do you trust the temperature gauge?
Water at sea level boils at 100c and a pressurised car cooling system with antifreeze mix will take that easily over 115c. I could be wrong but I don't think your problem is due to the water boiling.
Pretty sure I have read about a dye that can be added to the water that will change colour on contact with the combustion gases.
[Edited on 8/1/20 by 02GF74]
Visit China. Meet the child that made your trainers.
Oddified
posted on 8/1/20 at 09:16 PM Reply With Quote
I'd 2nd the suggestion to not discount the head gasket. Whilst not a bike engine, i had the same thing myself, perfect on the road, pass a sniffer test but on track blew some water out after a good thrashing. Tried all sorts (inc water mixes, water wetter, high pressure cap etc etc), last resort changed the head gaskets..instantly fixed it and now running standard antifreeze mix and regular pressure cap.
Ian
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Oddified 's Aim
