Author: Subject: Has My Hire Car Got a Ghost?
John P
posted on 14/1/20 at 02:22 PM Reply With Quote
Iíve been driving a Ford Focus hire car for a few days whilst some work is done on my normal car.
Itís a 1.0 Litre Zetec so fairly basic but it does have an automatic electric parking brake and also stop / start technology.
After reversing into my drive the auto parking brake comes on and the stop / start feature switches the engine off after which I would normally switch off using the ignition key and leave the car.
On two occasions now, whilst the ignition was still switched on, but after the auto parking brake was on and the engine turned off by the stop / start technology, I was surprised when the steering wheel suddenly moved about 25 mm to the left and the engine re-started.
Iím fairly sure I didnít touch any of the controls so whatís happening?
Wonít affect me as the car goes back tomorrow but Iíd love to know what might cause this. Itís certainly a bit unnerving.
John.
russbost
posted on 14/1/20 at 02:45 PM Reply With Quote
Engine is restarting presumably because the stop/start has recognised battery voltage has dropped below what it regards as satisfactory, so it starts the engine to recharge. As the engine starts power steering kicks in & causes the system to take up any "wind up" in the system, hence the steering wheel moves
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
loggyboy
posted on 14/1/20 at 02:49 PM Reply With Quote
Does it have an autopark assist? might be mechanical notification of it being triggered?
Mistral Motorsport
JAG
posted on 14/1/20 at 03:07 PM Reply With Quote
I think Russbost has it pretty much correct.
Auto Stop/Start does check a lot of stuff before stopping the engine and has a lot of triggers that will cause it to restart the engine. Something is triggering the system to re-start and that is causing the electrically assisted power steering to kick a little as the power comes back on.
Justin
posted on 14/1/20 at 03:25 PM Reply With Quote
Don't know why it's exhibiting the behaviour, but is there a means of disabling the auto start/stop feature?
If you can disable it that may well prevent it behaving as you describe.
fishywick
posted on 14/1/20 at 04:29 PM Reply With Quote
Ahh technology.
On a similar note, a female friend of ours parked and locked her new Range Rover in the garden centre car park. She returned an hour later to find the car still locked and the engine running !
Nickp
posted on 14/1/20 at 04:59 PM Reply With Quote
Yeah, haunted
gremlin1234
posted on 14/1/20 at 05:10 PM Reply With Quote
would a ghost of this car be an
out of focus experience ?
or perhaps a hire being...
[Edited on 14/1/20 by gremlin1234]
tims31
posted on 15/1/20 at 09:23 AM Reply With Quote
If the Auto stop/start has switched the engine off, you have not switched the ignition off and so in effect the car is still running.
I have a mondeo with this featute and if you stop and apply the parking brake and the engine is not needed at that time it will switch off but restart when needed, ie run the A/C or recharge the battery etc. The car will only switch off when you press the stop start ignition button.
Build: http://www.martinsfurybuild.co.uk/
ian locostzx9rc2
posted on 15/1/20 at 10:35 PM Reply With Quote
As said in the last post the wasnít switched off itís only switched off once you have pressed the ignition button
