Author: Subject: MX5 7" ring and pinion 4.1 ratio
APR
posted on 20/1/20 at 09:14 PM Reply With Quote
Anyone got a mx5 NB diff with the 4.1 ratio they want to move on ?
or just the ring and pinion ?
[Edited on 20/1/20 by APR]
Paul_Arion
posted on 22/1/20 at 10:00 AM Reply With Quote
I may well have a couple of these going spare - need to check the ratio but should be a 4.1:1. I am about to fit a 4.778 ratio from a Kia Sportage into my sprint / hillclimb MX5. I'll have a look and let you know
APR
posted on 22/1/20 at 02:25 PM Reply With Quote
Thanks Paul
Paul_Arion
posted on 22/1/20 at 06:05 PM Reply With Quote
Hi
Just checked and yes I do indeed have a 4.1:1 ratio diff going spare here - its an open diff with 41 tooth crownwheel and 10 tooth pinion. All of the NBs run the 7" diff which this is - but is from my very late mk1 so shouldn't make any difference. It was removed from the rear pumpkin a month or so and has been stored in box the garage since. Nothing has been touched and all feels nice and smooth - I have another diff that will be getting the 4.625 ratio this weekend that I have been dismantling
I also have another open diff complete with the rear pumpkin that was in my car for 100 miles or so - that should also be a 4.1 ratio but hasn't been opened up at all. I can check that if required.
If these are of any interest then drop me a PM and I can sort some pictures if requried. I am near Wolverhampton but could arrange a courier via DPD
cheers
Paul
[Edited on 22/1/20 by Paul_Arion]
APR
posted on 22/1/20 at 07:09 PM Reply With Quote
sent you a u2u Paul
