Author: Subject: Comfortable R1 RPM @ 110km/h (68mph)?
woodsy144
posted on 21/1/20 at 10:20 PM Reply With Quote
Hello,
I am trying to finalise my gearing. Being chain drive I can choose.
But not being a bike man, I am not overly familar with bikes.
Question, I want to be able to cruise at 110km/h (68mph) in 6th.
What RPM is a comfortable cruising RPM for an R1?
[Edited on 21/1/20 by woodsy144]
CosKev3
posted on 22/1/20 at 06:12 AM Reply With Quote
Mine was horrible at 7000rpm at circa 70mph,that was running on 3.64 sierra diff.
Fitted a 3.38 diff and it was circa 6300rpm at 70mph which was much better.
Presume you will be looking at much lower rpms using a chain diff?
woodsy144
posted on 22/1/20 at 06:39 AM Reply With Quote
That is beauty of a chain drive, I can design to what ever I want.
But trying to find the 'sweet spot' between high speed cruising and low speed drivability is the struggle.
Engine is a 08 R1, Tyres are 195/50R15
russbost
posted on 22/1/20 at 08:11 AM Reply With Quote
Running a ZZR1400 with chain drive I have 4,500rpm at 70mph, which is great, but I doubt the R1 is as forgiving at low revs as the ZZR.
Diff ratio is 3.28 running 14:46 sprockets, tyres are 255/45/17 so you need to factor the bigger circumference in for a straight comparison, there isn't much of a downside except when 2 up on a hot sticky day when the tyres are warm, if you go for a semi fast start then there can be a fractional bog down until either revs pickup or wheels spin or combination of both, if you're really booting it it's not an issue as you can always break traction anyway
Makes it more economical on a cruise too if that's worth considering
Furore Formula Car - the only two seater modern Formula Car lookalike. I no longer run Furore Products or Furore Cars Ltd, but would still highly recommend them for Acewell dashes, projector headlights, dominator headlights, indicators, mirrors etc, best prices in the UK! Take a look at http://www.furoreproducts.co.uk/ or find more parts on Ebay, user names furoreltd & furoreproducts, discounts available for LCB users.
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member   russbost 's Aim
adithorp
posted on 22/1/20 at 02:34 PM Reply With Quote
My fury R1 is around 1000rpm/10mph so at 100kph it'd be around 6000rpm. It'll happily cruise all day at 8000rpm. Only issue with that gearing is 1st gear is a bit long so high geared off the line but will hit 72mph in first
http://jpsc.org.uk/forum/
ReMan
posted on 22/1/20 at 10:53 PM Reply With Quote
Simmilar to Fireblade so 6-7000 is comfortable for the engine
6000 more comfortable for ears, 7000 better pick up
it will be somewhere around 1000/10mph in top as its pointless gearing for 150
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
jossey
posted on 26/1/20 at 08:31 PM Reply With Quote
Ain't seen you for years at the track adi. Miss you sat up my butt until I spin off the track.
I've gone and bought an r1 5vy but need ye help when you have a min on that alternator issue. I need a magneto if you have one to sell. Was debating in buying a whole engine as a spare. What's ye thoughts
On the rpm I found 6k at 70 good for the 893 I had with 318 diff but too slow on set-off with 51 in 1st
[Edited on 26/1/20 by jossey]
David Johnson
View User's Profile E-Mail User Visit User's Homepage View All Posts By User U2U Member This User Has MSN Messenger
