Author: Subject: Documenting the Donor Vehicle
geedle
posted on 27/1/20 at 12:51 PM Reply With Quote
I dragged home an MX5 for my Haynes project. I'm just about to start stripping it. Just a few questions about the donor:
  1. I read somewhere that it was a good idea to take photos of the donor and document the parts you take from it. Is this necessary? What exactly should I show? And is this for when I apply for a V5?
  2. Some suggested that the VIN plate should be removed and kept. Should it?
  3. When I am done with the shell of the MX5, I notify the DVLA that I scrapped it myself (yellow part of the V5 I think). Will metal merchants take the shell without the V5/VIN and just treat is as scrap metal rather than a car?
Thanks, Geedle.
ianhurley20
posted on 27/1/20 at 03:18 PM Reply With Quote
Originally posted by geedle
Thanks, Geedle.
When you register the car and also for IVA you will need to prove 'amateur build' so take loads of photos of the build. When you do apply it will give you a choice of what to include in the applications.
VIN plate is a problem area. I removed mine on my MX5 and had no problems, a friend removed his from his ST 170 and had all sorts of issues when scrapping the shell with the yard it was weighed in to. Got round it but they were not very happy. Probably would have been better to cut it into smaller pieces and weigh them in just as scrap metal.
KEEP the V5. You will need it at registration. Include it with the documents you submit and it will be daelt with by DVLA at that stage. Don't forget to sorn the car though.
Have fun!
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
geedle
posted on 27/1/20 at 04:43 PM Reply With Quote
That's exactly what I needed to know. Thanks.
Just gave the scrap metal place a ring: this one says that they don't care about the VIN plate, so long as I've told the DVLA that I've scrapped it. And they don't care if it is in one piece or chopped up...
gremlin1234
posted on 27/1/20 at 07:49 PM Reply With Quote
Originally posted by geedle...so long as I've told the DVLA that I've scrapped it. ...
you are NOT scrapping it (yet), you are replacing the chassis with a new one
get a receipt for the scrap metal, so you can prove it was disposed of responsibly.
don't forget things like the wings and doors are well worth selling on separately too
ReMan
posted on 27/1/20 at 11:14 PM Reply With Quote
if you want an age related plate, you need to SORN it not scrap it
www.plusnine.co.uk
∙،. ˘≈ﺣ
View User's Profile Visit User's Homepage View All Posts By User U2U Member   ReMan 's ICQ status
John Bonnett
posted on 28/1/20 at 07:50 AM Reply With Quote
I would have thought it would get a Q plate. Can you explain this please?
geedle
posted on 28/1/20 at 08:22 AM Reply With Quote
Right - I think I hadn't understood properly. So I'm SORNing and not destroying the identity of the donor. If I do that, does it not mean that I keep the number plate that is currently on donor? I would like an age related plate rather than a Q plate...
Schrodinger
posted on 28/1/20 at 08:33 AM Reply With Quote
If you report the vehicle as being scrapped now then when you come to registering the new car you can't claim you are scrapping it again as the donor so you will have to SORN the donor, then you can get an age related plate, otherwise it will be a Q plate.
Keith
geedle
posted on 28/1/20 at 11:18 AM Reply With Quote
Right - I think I have it worked out now. Good catch - I would have messed that up! Thanks.
ReMan
posted on 28/1/20 at 11:23 AM Reply With Quote
Yes, assuming that you use sufficient parts from the donor, you can apply for an age related plate, you will never get the actual plate of the donor. Which gives you a future option of a private plate for instance and some people dont like Q's even though they are perfectly acceptable on a kit
www.plusnine.co.uk
∙،. ˘≈ﺣ
ReMan
https://www.gov.uk/vehicle-registration/kitconverted-vehicles
www.plusnine.co.uk
∙،. ˘≈ﺣ
geedle
posted on 3/2/20 at 08:17 AM Reply With Quote
Just one last question on this... I've nearly got the MX5 shell off the running gear. I want to scrap the shell and it seems that my local metal merchant will take it without an identity.
It'll likely be a couple of years before I get done with this project (3 young kids!). Is it OK to keep it on SORN when I don't have the biggest part of the car any more? Can't see why not, but I might have missed something.
Thanks.
ReMan
posted on 3/2/20 at 09:16 AM Reply With Quote
Yes correct.
Harvest the vin plates from the shell and take pictures. Other than that, no-one will be inspecting the donor
www.plusnine.co.uk
∙،. ˘≈ﺣ
geedle
posted on 3/2/20 at 10:11 AM Reply With Quote
Brilliant. Thanks. Wife will be happy not to have the rusting shell of a car sat on the drive for two years!
