Author: Subject: KOLN shafts
m8kwr
posted on 27/1/20 at 06:31 PM Reply With Quote
KOLN shafts
Hi
Does anyone have 1 or 2 half shafts for a koln axle
Memphis
posted on 3/2/20 at 09:51 AM Reply With Quote
Originally posted by m8kwr
Hi
What size axle? I'm changing my Koln 54" axle for a Capri 52" English. Still on car at the moment...but halfshafts easily removed when my new slide hammer arrives.
m8kwr
posted on 3/2/20 at 10:16 AM Reply With Quote
Hi
Length is 733mm. And uses a 72-76mm bearing I believe.
I believe there were 2 types. I think the one I have is from a mk3-5 2.3l
But who knows!!!
Memphis
posted on 3/2/20 at 02:04 PM Reply With Quote
Apparently the way to tell which you have is the distance from the diff flange to the casing. Big gap (15mm?) light duty axle; small gap heavy duty. I'm pretty sure mine's a light duty axle, which is why I'm changing it for an English with 16t half shafts and LSD. That and a big weight saving...
m8kwr
posted on 3/2/20 at 02:52 PM Reply With Quote
I have a feeling the one I have is heavy duty as a small gap.
It if you remove them and can give them bearing a measure that would be appreciated
Memphis
posted on 3/2/20 at 03:07 PM Reply With Quote
Will do; but I'm pretty sure they are different to yours.
Memphis
posted on 3/2/20 at 06:10 PM Reply With Quote
I think you have the Atlas axle which has 16 spline halfshafts. In which case there are a pair on EBay right now which should fit.
m8kwr
posted on 3/2/20 at 06:29 PM Reply With Quote
I have the 22 spline. So might be the light duty ones. That could be the problem!
Memphis
posted on 3/2/20 at 06:50 PM Reply With Quote
The Koln axle is considered to be quite weak, especially with those long halfshafts. May I ask what car is it in, and what engine?
m8kwr
posted on 3/2/20 at 06:52 PM Reply With Quote
It is in a tiger super 6, 2.0 zetec now, used to have a 2.0 pinto in.
Memphis
posted on 3/2/20 at 09:11 PM Reply With Quote
Probably not what you want to hear, but you could change it for a shorter, stronger axle and use wheels with more negative offset, or use a Cortina heavy axle. Yours is definitely a light duty axle if it has 22 spline shafts and diff.
The problem with the Koln axle is that it's very heavy but also very weak.
