Author: Subject: For Sale: GSXR 1000 Turbo, Quaife QDF7ZR Transmission and Electric Reverse
cloudy
posted on 4/2/20 at 10:59 PM Reply With Quote
Turnkey Turbo GSXR 1000 setup
Asking 5000 for everything including the Engine, ECU, Quaife LSD, chain drive, transmission box, electric reverse,fuel tank/pump and wiring loom - Open to offers on just the engine too. Basic CAD model including all mounting positions supplied. Engine not yet dyno'd, but will include a solid starting map - There is a wideband sensor feeding the ECU for autotune. Would expect it's making around 230hp. Short video of it running
https://youtu.be/S1JQnx-RYNg
Engine:
Suzuki GSXR 1000 K2 Engine Block
GSXR 1000 Throttle Bodies
Subaru 440cc Blue injectors
Garrett T3 Turbo
Catalytic Converter - 2.5" Magnaflow Universal Cat
Carbon Plenum
Carbon Silencer
Air Filter Pipercross VM7000
NRC Timing Cover
Short Sump
Fuel Pressure Regulator
Bosch Type Fuel Pump
Injector Driver
Intercooler
Fuse Box & Wiring Loom
Hydraulic Clutch
Management:
Micro Squirt
Wideband - Dynojet Autotune & Bosch LSU4.9
TunerStudio License
Transmission:
Reverse motor and gear
Quaife QDF7ZR Chain-Drive Sealed Quaife ATB Helical LSD Differential
530 DID ZVM-X Chain
Please reach out if you need any specifics
www.warnercars.com
cloudy
posted on 14/2/20 at 08:20 PM Reply With Quote
Now up on eBay
Link
www.warnercars.com
stulemanski
posted on 19/2/20 at 02:09 PM Reply With Quote
Way out of my budget, but just wanted to say that is beautiful.
(You might want to put a reserve on that ebay listing...)
