Author: Subject: Pinto plumbing
Nick
posted on 15/2/20 at 09:37 PM Reply With Quote
Pinto plumbing
Hey people,
What is the correct way to run the pipes on a pinto running weber, capless radiator, no heater and a expansion tank.
Look forward to hearing from you you all.
Nick
posted on 16/2/20 at 08:31 AM Reply With Quote
Try the search facility, itís been covered loads of times
Nick
posted on 16/2/20 at 08:52 AM Reply With Quote
That is very true. Which I have already done and have a thousand different answers as complicated as a bad wiring diagram.
Just seeing if someone was willing to post a helpful answer with an arrangement that they had used successfully.
snapper
posted on 16/2/20 at 09:20 AM Reply With Quote
Itís simple.
Header tank feed to bottom radiator hose
Water pump 16mm output to Pinto head via manifold. I route this above radiator top hose with a T piece screw cap to bleed air when required.
Radiator overflow to header tank
Header tank overflow/pressure relief to drainpipe or expansion tank.
[Edited on 16/2/20 by snapper]
I eat to survive
I drink to forget
Nick
posted on 16/2/20 at 09:41 AM Reply With Quote
Brilliant, but what about radiator top hose.
jacko
posted on 16/2/20 at 05:45 PM Reply With Quote
As Snapper says even though mine was plumed different it seams there are a few different ways
Mine was plumed this way
Back of water pump to bottom of expansion tank
Fron inlet manifold to top of expansion tank
Thermostat housing to top of rad
Big water pump pipe to bottom of rad
If you look at my photo archive you will see some pictures of the engine bay
Ps I don't have the car now
Graham
snapper
posted on 17/2/20 at 08:49 AM Reply With Quote
Just goes straight to the radiator, I pot the fan switch in there if you donít have a radiator with a threaded bung for one
I eat to survive
I drink to forget
