Author: Subject: Brakes pull to left - only after not braking for some time
Crazysurf
posted on 19/2/20 at 07:02 PM Reply With Quote
I have an MG Midget (2ltr Zetec - not related) and have a strange problem that if I have been travelling for some time (e.g. on the motorway) and brake, it pulls to the left but then, if I brake again, all is good. Any ideas?
JAG
posted on 19/2/20 at 08:10 PM Reply With Quote
Yeah - one caliper (right hand side, probably the front) is seizing slighty - it's happening while you're driving but not using the brakes.
After the first apply, when the brakes pull, the seizing eases off and it works fine again for a while. Until you don't brake for a while - then the problem repeats.
Best way to relieve the issue is replace the offending caliper.
Justin
cliftyhanger
posted on 19/2/20 at 08:42 PM Reply With Quote
Indeed. But I would be buying a seal kit and doing both calipers. Not difficult as long as the pistons are not seized solid! (which yours are not by the sounds of it)
number-1
posted on 19/2/20 at 08:44 PM Reply With Quote
Replace the caliper seals on both sides. Also remove and grease the pistons. Its a simple job and cheap to do.
cliftyhanger
posted on 19/2/20 at 10:08 PM Reply With Quote
And use red brake/rubber grease. Copper grease is NOT suitable for seals/pistons/bleed nipples etc
JAG
posted on 19/2/20 at 10:27 PM Reply With Quote
I'd replace rather than re-build but that's your call. However...
NEVER use a normal Mineral Oil based lubricant (grease, oil, WD40 etc...) on brake caliper seals.
The rubber they are made from will not tolerate it and the seal will gradually deteriorate until your brakes fail!
IF you want to lubricate them as you rebuild the caliper use the DOT brake fluid.
Justin
steve m
posted on 20/2/20 at 12:14 AM Reply With Quote
I would, and have done, replace the seals, and pistons in the front calipers,
As long as everything is spotlessly clean, and rust free, the brakes will work 100%
I did it myself on my 7, as had similar issues, and the brakes, and driving were perfect afterwards
steve
Crazysurf
posted on 20/2/20 at 07:19 AM Reply With Quote
Thank you guys :-)
Bluemoon
posted on 20/2/20 at 10:45 AM Reply With Quote
I used bigg red who supplied me with stainless steel pistons and seals. In theory the pistons should not rust and pit like the originals, great for a car that is standing over winter...
[Edited on 20/2/20 by Bluemoon]
View User's Profile View All Posts By User U2U Member   Bluemoon 's Yahoo
AlexXtreme
posted on 20/2/20 at 01:05 PM Reply With Quote
I had similar problem and did as the other said and refurbed the calipers my self.
Brought a kit for the seals and by accident saw a company selling st.steel pistons on ebay which were fantastic quality.
Use a car air compressor to remove the old pistons.
gremlin1234
posted on 20/2/20 at 06:51 PM Reply With Quote
brake disk runout / slight warping, or failing wheel bearings can also cause symptoms like this.
(they knock the pads back a tiny bit further than the other side)
StrikerChris
posted on 20/2/20 at 10:19 PM Reply With Quote
If its a single piston caliper on sliders I had similar years ago. Turned out the slides were worn (not seized),causing the caliper to cock and jam occasionally. Wasn't obvious at first, as every time I had the wheel off it all seemed free.
