Author: Subject: Megajolt ECU setup
ttalps2000
posted on 20/2/20 at 12:48 PM Reply With Quote
Megajolt ECU setup
Got a Megajolt ecu setup (ignition only) with the Ford EDIS module, coil pack and bracket, leads and VR sensor cable. All setup for TPS input, however you could put back in the resistor that switches it back to MAP if required. it has the MAP sensor in the ecu. Will require a new plug for the wiring.
Has a hard rev limiter fitted also which was an upgrade at the time.
Was used on my Zetec for 2 years. Going to TB's now so no longer required. All in good working order and never had an issue with it. Cost me 400 new from Trigger Wheels.
225 posted.
macc man
posted on 20/2/20 at 06:31 PM Reply With Quote
You have a U2U.
