Author: Subject: BMW E46 Auto gearbox oil change
rf900rush
posted on 15/3/20 at 10:28 AM Reply With Quote
Hi All
Just bought a cheapish 325 E46 BMW estate (2003),and I would like to change the Gear box oil.
I have seen a couple of youtube videos on the subject, but most are USA ones. and do not give much info on the oil needed.
What I need, is which oil to use. I don't really what to go down the high performance 15 a liter road, if it is unnecessary.
Any suggestions on decent budget and recommended ones.
posted on 15/3/20 at 01:32 PM Reply With Quote
Ask your local motor factors, they will probably have a listing for it. Might also be worth changing the oil filter as well?
posted on 16/3/20 at 12:07 PM Reply With Quote
Probably worth getting a Haynes manual for the car. They list services parts - fluids, filters etc. for the vehicle. It'll show you how the method for draining and refilling the gearbox + checking the level as well.
Mr Whippy
posted on 16/3/20 at 12:14 PM Reply With Quote
you have to be very careful to follow the correct process with autoboxes or they can be damaged, as above get a manual, I'd not blindly follow a youtube vid on how to do it as you can't be sure they are doing it correctly.
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Mr+Whippy 's Aim
