Author: Subject: Zetec Oil Level
johnemms
posted on 27/3/20 at 08:23 PM Reply With Quote
Zetec Oil Level
Fairly straight forward thought..
An original Focus Zetec motor has an 8 degree tilt towards dipstick in the engine bay.
Mine is now mounted level 0 degrees in the kittycar..
Is it fair to assume my low level dipstick mark now becomes my high level mark
Don't think it matters really but just one of those locost thoughts ...
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
pmc_3
posted on 28/3/20 at 08:41 PM Reply With Quote
If you're using a different sump it's normally altered to be flat not tilted so I think you just read the dipstick as normal.
paulf
posted on 29/3/20 at 06:38 PM Reply With Quote
I have always just filled mine to the normal level on the dipstick the oil level in relation to the crank will remain the same although the sump holds less.
Paul.
